fletcherjames1 Posted January 7, 2025 Posted January 7, 2025 Just got the r3 as the xr1000 does not feel good. What is the optimal setup for competitive bo6, or how do I find the optimal setup for me as I suppose it will be different for everyone please?
Administrators Netduma Fraser Posted January 7, 2025 Administrators Posted January 7, 2025 It will be different for everyone, the best thing to do is experiment with the settings and play games, monitor how it feels with this setting set in this specific way and adjust from there. The simple answer though really is as always, Geo-Filter to get the closest servers to you - Congestion Control at a level that eliminates any lag caused by all devices on the network being used. SmartBOOST prioritizing what you care about. Behringer-93 1
fletcherjames1 Posted January 7, 2025 Author Posted January 7, 2025 Okay thankyou, where is congestion control on dumaos4?
Administrators Netduma Fraser Posted January 7, 2025 Administrators Posted January 7, 2025 Ping Optimizer > Advanced fletcherjames1 1
fletcherjames1 Posted January 9, 2025 Author Posted January 9, 2025 I've tried quite a few different settings, but my isps router feels so much better in game. I'm not sure why that is. Behringer-93 1
Administrators Netduma Fraser Posted January 9, 2025 Administrators Posted January 9, 2025 What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode
fletcherjames1 Posted January 10, 2025 Author Posted January 10, 2025 Plusnet Hub Two and I put it in bridge mode. I also have the XR1000, but that also feels really bad Â
fletcherjames1 Posted January 10, 2025 Author Posted January 10, 2025 I have fibre, 800-900 down and 120 up. All connected with cat8 ethernet cables. Behringer-93 1
Administrators Netduma Fraser Posted January 11, 2025 Administrators Posted January 11, 2025 I've given you Early Access, we just posted a new firmware there yesterday, try that and see if works better https://forum.netduma.com/forum/151-netduma-r3-early-access/
bob868tm Posted January 11, 2025 Posted January 11, 2025 to add to this conversation i quit using my r3 been a user since r1 to the xr models but i dont get any good games no more, currently am just playing direct tru my isp modem and feels much better even the pings and hit detection is better David J 1
Administrators Netduma Fraser Posted January 11, 2025 Administrators Posted January 11, 2025 51 minutes ago, bob868tm said: to add to this conversation i quit using my r3 been a user since r1 to the xr models but i dont get any good games no more, currently am just playing direct tru my isp modem and feels much better even the pings and hit detection is better Sorry to hear you're having that experience, I'd suggest making a new topic and we can help you there
David J Posted January 11, 2025 Posted January 11, 2025 5 hours ago, bob868tm said: to add to this conversation i quit using my r3 been a user since r1 to the xr models but i dont get any good games no more, currently am just playing direct tru my isp modem and feels much better even the pings and hit detection is better sad to say my son had did the same thing and went with the asus ax11000....a little to expensive for me but he isnt having any trouble either and just signs in and plays and according to him hes getting better games.
Administrators Netduma Fraser Posted January 12, 2025 Administrators Posted January 12, 2025 3 minutes ago, David J said: sad to say my son had did the same thing and went with the asus ax11000....a little to expensive for me but he isnt having any trouble either and just signs in and plays and according to him hes getting better games. Glad to hear they're having a good experience, if we're not given the opportunity to help we can't unfortunately. It's a router that requires fine tuning and experimentation to find what works best, it may require a bit more effort but the pay off will be better.
David J Posted January 12, 2025 Posted January 12, 2025 15 minutes ago, Netduma Fraser said: Glad to hear they're having a good experience, if we're not given the opportunity to help we can't unfortunately. It's a router that requires fine tuning and experimentation to find what works best, it may require a bit more effort but the pay off will be better. that wasnt a dig against the company or router....just his preference....I still have decent games with my R3....sometimes its off...but overall..its good Â
Administrators Netduma Fraser Posted January 12, 2025 Administrators Posted January 12, 2025 9 hours ago, David J said: that wasnt a dig against the company or router....just his preference....I still have decent games with my R3....sometimes its off...but overall..its good I totally understand and appreciate that some people may not want to tinker very much. It would be remiss of me not to try and get people to use the router for the reason they bought it in the first place and most often if someone doesn't use it anymore it's because the settings are too much or not fully understood and that's where I come in  DanyKTM and David J 1 1
fletcherjames1 Posted January 13, 2025 Author Posted January 13, 2025 Im only getting 500-600 download on the router for some reason, just done the firmware update
Administrators Netduma Fraser Posted January 13, 2025 Administrators Posted January 13, 2025 30 minutes ago, fletcherjames1 said: Im only getting 500-600 download on the router for some reason, just done the firmware update What speeds are you expecting/pay for? Have you factory reset after the update?
fletcherjames1 Posted January 13, 2025 Author Posted January 13, 2025 when I test with my isps router I get 800-900, 920 a lot of the time. I did reset yes
Administrators Netduma Fraser Posted January 13, 2025 Administrators Posted January 13, 2025 19 minutes ago, fletcherjames1 said: when I test with my isps router I get 800-900, 920 a lot of the time. I did reset yes What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g R3 in its DMZ, modem/bridge mode Are ALL devices connected to the R3? How have you setup Congestion Control? How have you setup SmartBOOST?
fletcherjames1 Posted January 13, 2025 Author Posted January 13, 2025 Plusnet Hub 2. I only have my pc connected through ethernet, I will be adding my phone and laptop using wifi. Congestion control is set up by doing the auto ping optimisation. I had it on always, but now I have put it to auto. SmartBOOST was set to just gaming, but now I have just added call of duty and removed gaming to see if that is better.
fletcherjames1 Posted January 13, 2025 Author Posted January 13, 2025 The plusnet hub two is connected to the fibre modem on the wall using ethernet. Hub 2 is in bridge mode and connected into the r3s blue ethernet port. Then r3 is connected to my pc by etehrnet. All cat8 cables.
Administrators Netduma Fraser Posted January 13, 2025 Administrators Posted January 13, 2025 Okay that's all good - speed test bypass should be on as well so as long as you're not seeing any prioritized activity at the time the speed test should be as expected
