Suliman Posted January 2, 2025 Posted January 2, 2025 I am playing on 10 ms server from Qatar and I face an issue when gaming on Black ops 6, I always have disadvantage when combat where other players can see me first and shoot first, its a known issue its called shoot first die first, I am playing COD since 2010. is there a settings that can help enhance my connection experience, I have done all needful and I have a very stable and perfect connection, my Netduma R3 always keep having issue whenever I access it where it says I have to wait 4 mintues and nothing happens, then I have to restart my router, I am on latest firmware update
Administrators Netduma Fraser Posted January 2, 2025 Administrators Posted January 2, 2025 That's a very hard thing to help with in this instance, you're receiving a very low ping and so in terms of what the router can control it's doing well by all statistics. Try and force a different server further away, even though it'll have a higher ping, does it play any better for you? How are you trying to access? With what device/web browser? What URL are you using? By latest update do you mean public or early access?
Nj12 Posted January 2, 2025 Posted January 2, 2025 1 hour ago, Suliman said: I am playing on 10 ms server from Qatar and I face an issue when gaming on Black ops 6, I always have disadvantage when combat where other players can see me first and shoot first, its a known issue its called shoot first die first, I am playing COD since 2010. is there a settings that can help enhance my connection experience, I have done all needful and I have a very stable and perfect connection, my Netduma R3 always keep having issue whenever I access it where it says I have to wait 4 mintues and nothing happens, then I have to restart my router, I am on latest firmware update I have a server close to me with about 6ms, I do very poorly on that server. Enemies seem to get the beat on me first, I force to a server with 40ms and do much better.
Suliman Posted January 2, 2025 Author Posted January 2, 2025 will try the settings to different server, I am using web browser
Suliman Posted January 2, 2025 Author Posted January 2, 2025 can you give the best to filter settings in Geo Filter? shall I enable steady ping? increase the ping assist or not? stuff like this
Suliman Posted January 2, 2025 Author Posted January 2, 2025 the nearest server is Qatar, nothing after that
Nj12 Posted January 2, 2025 Posted January 2, 2025 2 minutes ago, Suliman said: the nearest server is Qatar, nothing after that Try steady ping in expert mode, add ping in increments of 5 and see how it plays.
Nj12 Posted January 2, 2025 Posted January 2, 2025 17 minutes ago, Suliman said: can you give the best to filter settings in Geo Filter? shall I enable steady ping? increase the ping assist or not? stuff like this Check your DM.
Administrators Netduma Fraser Posted January 2, 2025 Administrators Posted January 2, 2025 54 minutes ago, Suliman said: can you give the best to filter settings in Geo Filter? shall I enable steady ping? increase the ping assist or not? stuff like this The "best" settings are the ones that work best for you, not everyone will have the same experience as we all have different connections, different devices, different locations etc. Steady Ping increases your ping to absorb any spikes, I'm not sure what the stability of your ping is like but you can try with and without and see how it feels. Ping Assist is just a way to filter getting a server, if you want to force specific servers you want that at 0.
Krush Posted January 3, 2025 Posted January 3, 2025 The Qatar server is very isolated as you can see on Ping Heatmap, so most players in this region of the world must play there with a very varied ping (from 10 to 150ms or more) there is surely a script to not disadvantage players with a high ping (theoretical). I would try in your place to force another server. What does Ping Heatmap say for you on BO6 (screenshot please)?
Suliman Posted January 3, 2025 Author Posted January 3, 2025 unfortunately the nearest server after Qatar is UK and EU, I wont dare go on 80+ ping but I guess have no other choice than Qatar, might check if there is another thing to check
Administrators Netduma Fraser Posted January 3, 2025 Administrators Posted January 3, 2025 1 hour ago, Suliman said: unfortunately the nearest server after Qatar is UK and EU, I wont dare go on 80+ ping but I guess have no other choice than Qatar, might check if there is another thing to check Try the EU servers, they may play better than you think if you're being lag compensated
