kevin88230 Posted October 29, 2024 Author Posted October 29, 2024 I encountered this issue when adjusting connection speed and congestion control to get an A+.
Administrators Netduma Fraser Posted October 29, 2024 Administrators Posted October 29, 2024 I've given you Early Access, could you see if you get the same on this firmware please: https://forum.netduma.com/topic/57223-new-firmware-r3-dumaos-40402-disconnections-fix
Administrators Netduma Fraser Posted October 29, 2024 Administrators Posted October 29, 2024 What is the model of your phone and can you do a test using a wired PC?
Krush Posted October 31, 2024 Posted October 31, 2024 Salut @kevin88230 Il y a de grande chance que ce soit, soit un problème de câble entre ton PC et le R3, soit cela vient de la carte réseau de ton PC. Les vitesses sont correctes entre la bbox et le R3 selon le test de vitesse du R3 essayes de changer le câble et essayes de réinitialiser ta carte réseau sur ton PC Privilégiés un test en ethernet (filaire) Les tests en Wifi peuvent être aléatoires en fonction du matériel que tu utilises !
kevin88230 Posted November 1, 2024 Author Posted November 1, 2024 Salut @Fuzy, en débranchant les câble internet j'ai réussi à ravoir mon débit. Mais pour les réglages c'est vraiment dur un test je vais avoir un A+ et le test suivant un C sans même modifier les paramètres de vitesse Krush 1
Administrators Netduma Fraser Posted November 1, 2024 Administrators Posted November 1, 2024 I'd suggest testing with downloads while following: https://bit.ly/bufferbloat-test start with a high value e.g 95%, test, decrease 10%, test, decrease 10% etc, until you get to a value that is pretty good, then try 5% either side of that value to see if it can be improved. Important to note that Download/Upload on CC don't have to be the same value & you may have a better experience with differing values. This is more of a real world test as you're actually doing traffic you would normally do. Krush 1
