When it's red, I understand that there is no connection, but what does it mean when it's pink? Everything works fine; it's just pink, then it comes and goes. Last time it did that was a few weeks ago stayed for a few days, then it stopped and returned to the normal white LED.
There isn't actually an official meaning for this that's documented and I've not seen it before. Best guess is it's a failed update - do you notice any pattern to what has prompted it?
@LokiDI am pretty sure that means it having some sort of connection problem with the modem as that's your internet connection indicator and it should be a solid white.
  • 1 month later...
I also noticed this shade of colour for that light on my own XR1000 a few weeks back. Internet connection remained active and no noticeable difference with it.
The only issue I noticed that may or may not have been network related or related to this different light colour was a number of apps (BBC iPlayer, All4, Amazon Prime) thinking I was connected via a VPN and blocking my ability to stream (I had no VPN active). That issue is now resolved.
