ORAMAS Posted July 5, 2024 Posted July 5, 2024 Greetings, I have a small problem; I'm not sure if it's due to recent updates, but the range of my wifi signal, both 5 GHz and 2.4 GHz, disconnects at a distance of approximately 10 feet (3.5 meters) with just one wall in between. I would appreciate any help if there is a configuration that can amplify the range. Note: I separated both bands and tried other channels.
Administrators Netduma Fraser Posted July 5, 2024 Administrators Posted July 5, 2024 We've just posted another firmware in Early Access so worth trying that first and seeing if that helps at all. ORAMAS 1
joel82 Posted July 5, 2024 Posted July 5, 2024 Faser, so per all my emails and communications with you i finally dont have an issue with the internet disconnecting and having to reset but now i cant get my wifi to work properly unstable and its all over the place. currently, I show one bar but a few minutes later it will go back up. this has been happening all weekend.
Administrators Netduma Fraser Posted July 5, 2024 Administrators Posted July 5, 2024 1 hour ago, joel82 said: Faser, so per all my emails and communications with you i finally dont have an issue with the internet disconnecting and having to reset but now i cant get my wifi to work properly unstable and its all over the place. currently, I show one bar but a few minutes later it will go back up. this has been happening all weekend. Split the bands, give 2.4/5GHz different names and apply - you'll want to connect to 5GHz specifically for speeds Use a WiFi analyzer to find the least congested channel and change to that Experiment with the widths to see what gives better results Ensure it's in an elevated position - not on a metal surface Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible Set the antennae to this position _ | | _
ORAMAS Posted July 17, 2024 Author Posted July 17, 2024 Greetings! I would like to know if it is possible to replace the antennas of the team with ones with a higher dBi. The reason is that I have poor coverage literally, when I move from one room to another, the signal falls completely when passing through a wall, despite being near the router located in an open place. I have followed the recommendations and I even had to place a network extender on a single wall. It is important to mention that the wall is not concrete. Thanks.
Administrators Netduma Fraser Posted July 18, 2024 Administrators Posted July 18, 2024 23 hours ago, ORAMAS said: Greetings! I would like to know if it is possible to replace the antennas of the team with ones with a higher dBi. The reason is that I have poor coverage literally, when I move from one room to another, the signal falls completely when passing through a wall, despite being near the router located in an open place. I have followed the recommendations and I even had to place a network extender on a single wall. It is important to mention that the wall is not concrete. Thanks. In theory yes you could do that as long as the connectors are correct, I believe someone has done that in the past and noticed an improvement
