euphidra Posted June 29, 2024 Posted June 29, 2024 @Netduma Alex @Netduma Fraser Hi Fraser and Alex, why doesn't Adblocker block YouTube advertising on smart TVs in wifi mode? There is a list to be entered manually. The various adblock extensions on PC browsers work but on Netduma R3 they don't. P.S. When you set up the Hybrid VPN with steady ping the graph does not appear. Thank you. Now I install the firmware 4.0.227 Early Access R3.
Administrators Netduma Fraser Posted June 29, 2024 Administrators Posted June 29, 2024 YouTube ads are tricky because they're served on the same URL as the video itself so it makes it hard to block from the network side. It's something we're hoping to be able to work around in the future. Monsta, euphidra and Krush 3
