Eefo Posted April 29, 2024 Posted April 29, 2024 Hello everyone, as the title says, i am planning use this setup. Is this possible to use both devices? I know i can turn wifi off on r3 and use xr1000's wifi. but do i have to do something special or will it be just plug and play? Thanks.
Administrators Netduma Fraser Posted April 29, 2024 Administrators Posted April 29, 2024 Yes you can do that, just disable WiFi in WiFi settings on the R3. Then on the XR in Settings change the router mode to AP Eefo 1
Eefo Posted April 29, 2024 Author Posted April 29, 2024 2 minutes ago, Netduma Fraser said: Yes you can do that, just disable WiFi in WiFi settings on the R3. Then on the XR in Settings change the router mode to AP Thank you Fraser. Netduma Fraser 1
