docha34 Posted April 19, 2024 Author Posted April 19, 2024 4 minutes ago, TrayDay said: Try this iptables -t mangle -A PREROUTING -s PS5 IP HERE -j TEE --gateway PC IP HERE iptables -t mangle -A POSTROUTING -d PS5 IP HERE -j TEE --gateway PC IP HERE I also have a router like this You can't do that here?
TrayDay Posted April 19, 2024 Posted April 19, 2024 14 minutes ago, docha34 said: I also have a router like this You can't do that here? No, this will not work. I still believe it's best if you use a 'smart switch' for port mirroring. It's just easier. Sorry, I couldn't be more of assistance. But, you're more than welcome asking your question and situation in this forum here. As this forum is primarily about ASUS routers. https://www.snbforums.com/forums/asuswrt-merlin.42/
docha34 Posted April 19, 2024 Author Posted April 19, 2024 17 minutes ago, TrayDay said: No, this will not work. I still believe it's best if you use a 'smart switch' for port mirroring. It's just easier. Sorry, I couldn't be more of assistance. But, you're more than welcome asking your question and situation in this forum here. As this forum is primarily about ASUS routers. https://www.snbforums.com/forums/asuswrt-merlin.42/ I ordered your port like you said But it'll be here in two weeks. I live in South America and it's hard to order anything here. Plus it came out to almost 100 dollars instead of 20 dollars.) I'll text you for help when it arrives. Thank you so much. TrayDay 1
docha34 Posted April 24, 2024 Author Posted April 24, 2024 On 4/19/2024 at 1:14 AM, TrayDay said: No, this will not work. I still believe it's best if you use a 'smart switch' for port mirroring. It's just easier. Sorry, I couldn't be more of assistance. But, you're more than welcome asking your question and situation in this forum here. As this forum is primarily about ASUS routers. https://www.snbforums.com/forums/asuswrt-merlin.42/ Hey, buddy. I finally got my switch. Please help me to configure it what to connect where?
TrayDay Posted April 24, 2024 Posted April 24, 2024 You'll need three Ethernet cables. 1. For Switch 2. For PC 3. For PS5 Plug one cable from Swtich port 1 to any port on Netduma. Plug one cable from PC to port 4 of Switch. Plug one cable from PC to port 5 of Switch. Now, you will need to give your switch a static IP address Find the MAC address on the bottom of the Switch. Write this down or memorize it. Next visit the DUMAOS dashboard/home page. Either by going to 192.168.77.1 or dumaos/ The go-to settings, LAN, DHCP, and find the MAC address for the switch. I believe this is the location of DHCP to set static IP, I'm doing this off memory for the R2. Now, you may or may not see the mac address for the switch here. If you do not see the mac address of the switch here to give static IP. Reboot the R2 and visit this DHCP section again. You should now see MAC address of the switch. Give it a static IP. Then this time. Unplug the power cable from the switch and plug it back in to reboot the switch and for the swtich to get the new static IP number you have given. In my case, I chose the number 241. So, my switch IP is 192.168.77.241 Default user name and password for this login is admin admin Then click Monitoring Then port mirror Then enable port mirror, choose mirroring port, port 4 click apply. Then choose mirrored port, port 5, enable ingress, enable egress, click apply. Now, your pc is mirroring your PS5/console.
docha34 Posted April 24, 2024 Author Posted April 24, 2024 15 minutes ago, TrayDay said: Вам понадобятся три кабеля Ethernet. 1. Для коммутатора 2. Для ПК 3. Для PS5 Подключите один кабель от порта Swtich 1 к любому порту Netduma. Подключите один кабель от ПК к порту 4 коммутатора. Подключите один кабель от ПК к порту 5 коммутатора. Теперь вам нужно присвоить вашему коммутатору статический IP-адрес Найдите MAC-адрес в нижней части коммутатора. Запишите это или запомните. Затем посетите панель управления DUMAOS / домашнюю страницу. Либо перейдя на 192.168.77.1, либо на dumaos/ Перейдите в настройки, локальную сеть, DHCP и найдите MAC-адрес для коммутатора. Я полагаю, что это расположение DHCP для установки статического IP, я делаю это из памяти для R2. Теперь вы можете видеть здесь mac-адрес коммутатора, а можете и не видеть его. Если вы не видите здесь mac-адрес коммутатора, укажите статический IP. Перезагрузите R2 и снова посетите этот раздел DHCP. Теперь вы должны увидеть MAC-адрес коммутатора. Укажите ему статический IP. Тогда на этот раз. Отсоедините кабель питания от коммутатора и подключите его обратно, чтобы перезагрузить коммутатор и чтобы swtich получил новый статический IP-номер, который вы указали. В моем случае я выбрал номер 141. Итак, мой IP-адрес коммутатора 192.168.77.241 Имя пользователя и пароль по умолчанию для этого входа - admin admin Затем нажмите Мониторинг Затем зеркало порта Затем включите зеркало порта, выберите порт зеркального отображения, порт 4 нажмите применить. Затем выберите зеркальный порт, порт 5, включите вход, включите выход, нажмите применить. Теперь ваш компьютер выполняет зеркальное отображение вашей PS5 / консоли. Thank you so much Everything worked out. Now I can finally see how busy the server is in efootball ))))) ElBax978, Netduma Fraser and TrayDay 1 1 1
ElBax978 Posted May 24, 2024 Posted May 24, 2024 On 25/04/2024 at 00:26, docha34 said: Grazie mille. Ha funzionato tutto. Ora posso finalmente vedere quanto è occupato il server in efootball )))) How can you do that?
