speed test not working
jame0174
 Share
II cant get speed test to work for the life of me .I  restart my r3 and it show nothing .And i still get high latency with it even throw its lower with the xr1000.The geofilter has a mind of its own as well
We are aware Ping Optimizer/Speed Test isn't 100% reliable at the moment and it's something the team are working on. Those features can still work, it just may not be every time. In the meantime best to adjust Congestion Control manually in Ping Optimizer > Advanced.
Could you expand on the Geo-Filter issues? What firmware version are you on currently?
I did try it when it  when it came out and i had a lot of issues so i went back to .23.Unless this is a total new firmware
Factory reset can be done either via the interface or by holding the reset button in the back of the router for 30 seconds. Unplugging is just a reboot.
The firmware is attached to the first post on that link, there is also an alternate download link at the bottom of that post.
Please sign in to comment
You will be able to leave a comment after signing in
 Share
