Administrators Netduma Fraser Posted March 28, 2024 Administrators Posted March 28, 2024 The firmware should help as it fixes an issue which caused an instability with ping so hopefully that was the issue for you
Tru ELiTE Posted March 28, 2024 Author Posted March 28, 2024 yea I'm on 38 ping now. But I have seen on the router that is has lower ping then my xbox. I have seen the r3 get 33 to 35 ping on the North Carolina server but on the xbox I get 40 to 43. the virginia server stay a solid 38 ping steady the whole game. Any advice on congestion control always on or auto or low latency???? On another note I put the xbox in the DMZ I saw a Georgia Server on Halo Infinite which was 15-20ms any one seen this server?
Administrators Netduma Fraser Posted March 28, 2024 Administrators Posted March 28, 2024 I'd generally suggest Auto if you just want it working while gaming Tru ELiTE 1
Tru ELiTE Posted March 28, 2024 Author Posted March 28, 2024 do static routes help to connect to the server you want?
Administrators Netduma Fraser Posted March 29, 2024 Administrators Posted March 29, 2024 16 hours ago, Tru ELiTE said: do static routes help to connect to the server you want? I've heard in the past that it can help but I wouldn't suggest it generally
Tru ELiTE Posted April 16, 2024 Author Posted April 16, 2024 Is anyone else getting high pings on the servers that they want to play on? This is happening on Halo Infinite. Virginia server.
Administrators Netduma Fraser Posted April 16, 2024 Administrators Posted April 16, 2024 11 hours ago, Tru ELiTE said: Is anyone else getting high pings on the servers that they want to play on? This is happening on Halo Infinite. Virginia server. Do you get it on any other servers at all? If not it's likely that server is under load currently
Tru ELiTE Posted April 16, 2024 Author Posted April 16, 2024 No, I only play on the Virginia server because that's the best ping I get.
Tru ELiTE Posted April 16, 2024 Author Posted April 16, 2024 When I block that specific Virginia server and I connect to another Virginia server it goes back to normal. It can be a modem issue?
Administrators Netduma Fraser Posted April 16, 2024 Administrators Posted April 16, 2024 54 minutes ago, Tru ELiTE said: When I block that specific Virginia server and I connect to another Virginia server it goes back to normal. It can be a modem issue? In that case it will be that specific server is under load, you did the right thing! Tru ELiTE 1
Tru ELiTE Posted April 21, 2024 Author Posted April 21, 2024 How do you properly block twitch ads on the xbox series x using the netduma r3?
Administrators Netduma Fraser Posted April 21, 2024 Administrators Posted April 21, 2024 3 hours ago, Tru ELiTE said: How do you properly block twitch ads on the xbox series x using the netduma r3? I'm not sure if you'd be able to as it's likely they're served on the same domain as the actual stream (same issue with why YouTube can't be blocked currently)
Tru ELiTE Posted April 21, 2024 Author Posted April 21, 2024 I blocked the exact twitch stream url and still get the ads.
Administrators Netduma Fraser Posted April 21, 2024 Administrators Posted April 21, 2024 15 minutes ago, Tru ELiTE said: I blocked the exact twitch stream url and still get the ads. What URL is that?
Tru ELiTE Posted April 21, 2024 Author Posted April 21, 2024 this is the new I'm using now https://www.twitch.tv/
Administrators Netduma Fraser Posted April 21, 2024 Administrators Posted April 21, 2024 20 minutes ago, Tru ELiTE said: this is the new I'm using now https://www.twitch.tv/ If it was to work it would block the entire site, you'd have to find the specific ad URL but it would probably block the normal stream as well
Administrators Netduma Fraser Posted May 4, 2024 Administrators Posted May 4, 2024 15 minutes ago, Tru ELiTE said: does the netduma r3 have link aggregation? No it doesn't
Administrators Netduma Fraser Posted May 5, 2024 Administrators Posted May 5, 2024 2 hours ago, Tru ELiTE said: Is vpn available on the r3? It is in Early Access yes, you can find that here: https://forum.netduma.com/forum/151-netduma-r3-early-access/ go with the .170 version for the moment if you want to use the VPN
Tru ELiTE Posted May 17, 2024 Author Posted May 17, 2024 does anyone know what's the difference between a direct server vs traced server on halo infinite? my normal direct ping for the North Carolina server is 41 - 43 ms but the traced ping is 10-15 ms. has anyone noticed this? please assist and explain what this means. thanks in advance.
Administrators Netduma Fraser Posted May 17, 2024 Administrators Posted May 17, 2024 13 hours ago, Tru ELiTE said: does anyone know what's the difference between a direct server vs traced server on halo infinite? my normal direct ping for the North Carolina server is 41 - 43 ms but the traced ping is 10-15 ms. has anyone noticed this? please assist and explain what this means. thanks in advance. Where are you measuring this? If you're trying to do a trace to the actual server IP it is likely timing out and providing you with the ping response from the last hop that doesn't time out
Tru ELiTE Posted May 17, 2024 Author Posted May 17, 2024 Ping method is traced vs other servers is direct. what's the difference?
Administrators Netduma Fraser Posted May 17, 2024 Administrators Posted May 17, 2024 Basically what I mentioned before, direct it's pinging the server directly - traced it can't ping the server directly so it's running a trace and taking the last ping response
