Tearing Posted March 22, 2024 Share Posted March 22, 2024 I currently just got fiber little over a week ago suppose to get 1G down and up but anyways I’ve only gotten to about 700/200 with monkeying around and reading posts but is that typical or should I be seeing 1G /1G also when I test on my other internet which is phone line I get 5mbps and 1mbps up the test shows no jitter 20 ping to the server I am pinging but when I use my fiber I’m getting like 2 jitter 14-16ping I’ve only tested 1 time without no jitter and I’ve done prob 100+ tests I believe it’s the router causing this since is still beta any help would be appreciated thanks Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 22, 2024 Administrators Share Posted March 22, 2024 What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode Have you set your expected speeds? How do you have Congestion Control set in Ping Optimizer > Advanced? Is speed test bypass enabled? Link to comment Share on other sites More sharing options...
Tearing Posted March 22, 2024 Author Share Posted March 22, 2024 On 3/22/2024 at 3:02 PM, Netduma Fraser said: What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode Have you set your expected speeds? How do you have Congestion Control set in Ping Optimizer > Advanced? Is speed test bypass enabled? Expand R3 connected to a line straight from my isp No other router or modem as far as I know and wat u mean dmz modern bridge mode congestion control is set both 100% low latently only checked I also have turned off ipv6 on both wan and lan Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 22, 2024 Administrators Share Posted March 22, 2024 You don't have to worry about that due to how you have it setup so that is fine. What was the router/modem you had before - did you get full speeds through that? Whatever it was get its MAC address and in Settings on the R3 make it use that make address, reboot from the interface and see if the speeds are any better please. Link to comment Share on other sites More sharing options...
Tearing Posted March 23, 2024 Author Share Posted March 23, 2024 I never had a router modem before sadly I just got installed with the R3 at this house so anything any suggestions I’d like to get 0 jitter which happens sometimes but seems most of the time my download speed is all over the place where my upload seems accurate most of the time Link to comment Share on other sites More sharing options...
Tearing Posted March 23, 2024 Author Share Posted March 23, 2024 I’m also struggling to get open nat on my ps5 any suggestions Link to comment Share on other sites More sharing options...
TrayDay Posted March 23, 2024 Share Posted March 23, 2024 On 3/23/2024 at 5:15 PM, Tearing said: I’m also struggling to get open nat on my ps5 any suggestions Expand Place your PS5 in the DMZ. Reserve Your PS5 IP if it shows here. Then click SAVE. You should now have your PS5 in DMZ. You should be able to have OPEN NAT. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 23, 2024 Administrators Share Posted March 23, 2024 Disable SmartBOOST fully from the icon > Settings on the page then test, what do you get? Link to comment Share on other sites More sharing options...
Tearing Posted March 23, 2024 Author Share Posted March 23, 2024 Smart boost disabled also added PlayStation to the DMZ/port forwarding not really much of a difference not sure if I can do anything more jitter is the part I was told should be 0 Link to comment Share on other sites More sharing options...
Tearing Posted March 23, 2024 Author Share Posted March 23, 2024 On 3/23/2024 at 6:04 PM, TrayDay said: Place your PS5 in the DMZ. Reserve Your PS5 IP if it shows here. Then click SAVE. You should now have your PS5 in DMZ. You should be able to have OPEN NAT. Expand Do you know how to open nat for PlayStation network test as well ? It opened for when I’m in game but when I do speed test on station it’s nat 2 Link to comment Share on other sites More sharing options...
TrayDay Posted March 23, 2024 Share Posted March 23, 2024 On 3/23/2024 at 7:42 PM, Tearing said: Do you know how to open nat for PlayStation network test as well ? It opened for when I’m in game but when I do speed test on station it’s nat 2 Expand TYPE 1 is only when you're connected DIRECTLY to the MODEM. PS5 to MODEM. You will have Type 1. TYPE 2, is behind a router. You're Good with Type 2. Link to comment Share on other sites More sharing options...
Tearing Posted March 23, 2024 Author Share Posted March 23, 2024 I should be connoted right to the modem Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 23, 2024 Administrators Share Posted March 23, 2024 You'd have to test the speed with the PS out of the DMZ first. What Tray means is that NAT Type 1 you can only achieve by connecting the PS directly to the modem, NAT Type 2 is for modem > router > PS but its still open Link to comment Share on other sites More sharing options...
justin peryea Posted March 27, 2024 Share Posted March 27, 2024 On 3/22/2024 at 10:13 PM, Netduma Fraser said: You don't have to worry about that due to how you have it setup so that is fine. What was the router/modem you had before - did you get full speeds through that? Whatever it was get its MAC address and in Settings on the R3 make it use that make address, reboot from the interface and see if the speeds are any better please. Expand this is second time I have seen this how do I find the right Mac address if it is wrong Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 28, 2024 Administrators Share Posted March 28, 2024 On 3/27/2024 at 2:50 PM, justin peryea said: this is second time I have seen this how do I find the right Mac address if it is wrong Expand The previous router you used should have a maximum of two MAC addresses, they'd be printed on the label on the underside of it Link to comment Share on other sites More sharing options...
