Lsmith24 Posted March 6, 2024 Share Posted March 6, 2024 it won’t let me use the ping optimizer, keeps giving me an error code. and everytime i try to login via the app on my phone, it keeps saying unknown error occurred and won’t let me login Link to comment Share on other sites More sharing options...
Aspect of Wrath Posted March 7, 2024 Share Posted March 7, 2024 Restart router or power off then on again, this issue is going to be fixed next firmware. Link to comment Share on other sites More sharing options...
Lsmith24 Posted March 7, 2024 Author Share Posted March 7, 2024 okay thanks, will this only fix the login issue or will it fix the ping and login issue both? Link to comment Share on other sites More sharing options...
Freebandzz Posted March 7, 2024 Share Posted March 7, 2024 49 minutes ago, Aspect of Wrath said: Restart router or power off then on again, this issue is going to be fixed next firmware. How long intill next firmware update very soon or month away Link to comment Share on other sites More sharing options...
Aspect of Wrath Posted March 7, 2024 Share Posted March 7, 2024 38 minutes ago, Freebandzz said: How long intill next firmware update very soon or month away From what I've read it sounds like they figured out what was causing the issue, as for when I do not know but hopefully soon means sometime this month. I am still waiting to update R2 firmware coming "soon" said last year lmao. Link to comment Share on other sites More sharing options...
Lsmith24 Posted March 7, 2024 Author Share Posted March 7, 2024 is there a way i can access dumaos on my pc? i’ve seen where people do it and it may let me optimize my ping that way, but i can’t find it anywhere. that’s why i’ve done everything through my phone Link to comment Share on other sites More sharing options...
Aspect of Wrath Posted March 7, 2024 Share Posted March 7, 2024 2 hours ago, Lsmith24 said: is there a way i can access dumaos on my pc? i’ve seen where people do it and it may let me optimize my ping that way, but i can’t find it anywhere. that’s why i’ve done everything through my phone Try logging in using 192.168.77.1 on the web browser. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 7, 2024 Administrators Share Posted March 7, 2024 As above that'll help you login on a PC. For the app, uninstall it then re-install it, does that allow you to login? Link to comment Share on other sites More sharing options...
Lsmith24 Posted March 7, 2024 Author Share Posted March 7, 2024 i was able to get in through my pc, thank you so much Netduma Fraser 1 Link to comment Share on other sites More sharing options...
Lsmith24 Posted March 7, 2024 Author Share Posted March 7, 2024 it’s still not letting me do the ping optimization on my pc Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 7, 2024 Administrators Share Posted March 7, 2024 We are aware Ping Optimizer/Speed Test isn't 100% reliable at the moment and it's something the team are working on. Those features can still work, it just may not be every time. In the meantime best to adjust Congestion Control manually in Ping Optimizer > Advanced. Link to comment Share on other sites More sharing options...
Lsmith24 Posted March 7, 2024 Author Share Posted March 7, 2024 thanks for your help fraser, seriously. i appreciate it! when will i know when the optimization and all of that will be running smoothly? Netduma Fraser 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 7, 2024 Administrators Share Posted March 7, 2024 There will be an update and it would detail it in the change log on that update if included Link to comment Share on other sites More sharing options...
Lsmith24 Posted March 8, 2024 Author Share Posted March 8, 2024 okay i gotcha. i have a question tho, on my normal router i was getting a consistent 30ms ping on cod mw3 , i was just wondering if my ping will drop any below that when the update comes out for the ping issue. i’m getting anywhere from 40-60ms in game now with the r3. so i’m hoping once this is fixed, it’ll be able to drop lower than what i was normally getting. is that possible or? Link to comment Share on other sites More sharing options...
Aspect of Wrath Posted March 8, 2024 Share Posted March 8, 2024 4 hours ago, Lsmith24 said: okay i gotcha. i have a question tho, on my normal router i was getting a consistent 30ms ping on cod mw3 , i was just wondering if my ping will drop any below that when the update comes out for the ping issue. i’m getting anywhere from 40-60ms in game now with the r3. so i’m hoping once this is fixed, it’ll be able to drop lower than what i was normally getting. is that possible or? Try turning off stable ping on geo filter if you care more about lower ping because stable ping usually raises ping by 10 or more. Link to comment Share on other sites More sharing options...
PharmDawgg Posted March 8, 2024 Share Posted March 8, 2024 If you don’t like the amount of ping buffer that is applied by Steady Ping (Simple). do know with Steady Ping (Expert) you can manually set how much ping buffer is applied to stabilize you ping spikes. It is a pretty nice function. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 8, 2024 Administrators Share Posted March 8, 2024 Very likely Steady Ping as others have mentioned. In terms of can you get lower it really depends if there are other servers in your area that you ping lower to. You can check with Ping Heatmap Link to comment Share on other sites More sharing options...
