shahidwali13 Posted March 19, 2024 Posted March 19, 2024 3 minutes ago, banjo22 said: IPv6 was already disabled for the record. I have emailed about returning the device, not sure what the point of having PPPoE on it if it doesn't work correctly. You mention QOS on the XR1000 but I never had this issue over 2 years using it.. Hi brother i am going to buy xr500 soon so how was your experience before no issue on your xr1000 about heavy gameplay deley or ping issuesdoes this router changed your gaming experience as I am also ea fc 24 player
Administrators Netduma Fraser Posted March 19, 2024 Administrators Posted March 19, 2024 11 minutes ago, banjo22 said: IPv6 was already disabled for the record. I have emailed about returning the device, not sure what the point of having PPPoE on it if it doesn't work correctly. You mention QOS on the XR1000 but I never had this issue over 2 years using it.. We haven't determined if that is the issue, did you try disabling IPv6?
banjo22 Posted March 19, 2024 Author Posted March 19, 2024 5 minutes ago, shahidwali13 said: Hi brother i am going to buy xr500 soon so how was your experience before no issue on your xr1000 about heavy gameplay deley or ping issuesdoes this router changed your gaming experience as I am also ea fc 24 player Hi mate, XR1000 was for most a good experience however I did experience a fair whack of disconnects that were often down to DHCP releases, I eventually had enough of it and changed to the R3 hoping all my issues would go away. I no longer get disconnects just lots of none responses followed by speed up lag If you are a EAFC player then you'll know how stressful Champs is on a weekend, can't be doing with lag for them!
banjo22 Posted March 19, 2024 Author Posted March 19, 2024 6 minutes ago, Netduma Fraser said: We haven't determined if that is the issue, did you try disabling IPv6? Hi, see the start of my post it was already disabled, must have been by default, I don't recall ever seeing it.
shahidwali13 Posted March 19, 2024 Posted March 19, 2024 9 minutes ago, banjo22 said: Hi mate, XR1000 was for most a good experience however I did experience a fair whack of disconnects that were often down to DHCP releases, I eventually had enough of it and changed to the R3 hoping all my issues would go away. I no longer get disconnects just lots of none responses followed by speed up lag If you are a EAFC player then you'll know how stressful Champs is on a weekend, can't be doing with lag for them! yes brother i know the pain some times good gameplay other times heavy gameplay that's why I am searching more on this router I hope you get the fix and last thing does router worth it for ea fc 24 f no issues like bugs etc i
Administrators Netduma Fraser Posted March 19, 2024 Administrators Posted March 19, 2024 Could you disable Speed Test Bypass and also provide a screenshot of your SmartBOOST page please? Have you put anything in the DMZ?
banjo22 Posted March 19, 2024 Author Posted March 19, 2024 6 minutes ago, Netduma Fraser said: Could you disable Speed Test Bypass and also provide a screenshot of your SmartBOOST page please? Have you put anything in the DMZ? Where do i find speed test bypass? Nothing in the DMZ no Smartboost attached
Administrators Netduma Fraser Posted March 19, 2024 Administrators Posted March 19, 2024 It's in Ping Optimizer > Advanced. That looks fine, can you show what it looks like when you have the saturated traffic and gaming at the same time? What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode
banjo22 Posted March 19, 2024 Author Posted March 19, 2024 29 minutes ago, Netduma Fraser said: It's in Ping Optimizer > Advanced. That looks fine, can you show what it looks like when you have the saturated traffic and gaming at the same time? What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode See attached. The R3 is connected to a Draytek modem, no config or anything, the ISP details then input into the R3 PPPoE. Attached, the DOSSAL is the NAS downloading.
Administrators Netduma Fraser Posted March 20, 2024 Administrators Posted March 20, 2024 On SmartBOOST go to Settings ( ) > Settings and double check it is definitely enabled. Then go back to the menu > Favorites/Primary Profile > Click the line icon top right then reserve 5Mbps bandwidth for the game or for ports 1024 - 65535 source and destination, tcp & udp and then play and see if it is better please
banjo22 Posted March 20, 2024 Author Posted March 20, 2024 9 hours ago, Netduma Fraser said: On SmartBOOST go to Settings ( ) > Settings and double check it is definitely enabled. Then go back to the menu > Favorites/Primary Profile > Click the line icon top right then reserve 5Mbps bandwidth for the game or for ports 1024 - 65535 source and destination, tcp & udp and then play and see if it is better please Done, will see how it gets on, probably be at the weekend Netduma Fraser 1
shahidwali13 Posted March 20, 2024 Posted March 20, 2024 3 hours ago, banjo22 said: Done, will see how it gets on, probably be at the weekend Bro check your dm when you get free
banjo22 Posted March 21, 2024 Author Posted March 21, 2024 On 3/20/2024 at 12:00 AM, Netduma Fraser said: On SmartBOOST go to Settings ( ) > Settings and double check it is definitely enabled. Then go back to the menu > Favorites/Primary Profile > Click the line icon top right then reserve 5Mbps bandwidth for the game or for ports 1024 - 65535 source and destination, tcp & udp and then play and see if it is better please So it happened tonight, but I have some more information that will hopefully help. When I was in an EAFC online game, I switched my PC on; when it got to the Windows screen that is when my controller stopped responding and speed-up lag occurred, I assumed this wasn't a coincidence. I did my turn my PC off and on again hoping to replicate the issue but it didn't do it second time around. I assume in the past this could be a new device connecting to the network? DHCP lease renewing? Any ideas? I'm downloading right now on my NAS whilst in a game and there is no speed-up lag at any point. Just happened again now, nothing to note to why it happened.
Administrators Netduma Fraser Posted March 22, 2024 Administrators Posted March 22, 2024 Okay interesting, if you try playing without the controller entirely, do you get the same issue? Could you get the logs from the Troubleshooting > Advanced please and that may tell us more
banjo22 Posted March 22, 2024 Author Posted March 22, 2024 9 hours ago, Netduma Fraser said: Okay interesting, if you try playing without the controller entirely, do you get the same issue? Could you get the logs from the Troubleshooting > Advanced please and that may tell us more Yes I should have got the logs when it happened. I’ll get them the next time. when I say the controller stops responding, it’s the massive lag spike where the game stops responding, then it catches up with itself, there isn't wrong with the controller.
Administrators Netduma Fraser Posted March 22, 2024 Administrators Posted March 22, 2024 Ah okay understood, if you get the logs that should tell us more
banjo22 Posted March 22, 2024 Author Posted March 22, 2024 It just happened again at 21:58 I'm playing a Champs game, 2-2 and then the below happens. It's lost me the game, and I'm fuming, tbh. How long does your support take to come back? I can't use this anymore, I'd prefer my decade old TP Link right now. Log: Fri Mar 22 21:45:00 2024 kern.info kernel: ash (29119): drop_caches: 3 Fri Mar 22 21:45:17 2024 user.notice overwatch-initd:: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied Fri Mar 22 21:45:24 2024 user.notice overwatch-initd:: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied Fri Mar 22 21:45:25 2024 user.notice overwatch-initd:: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied Fri Mar 22 21:45:25 2024 user.notice overwatch-initd:: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied Fri Mar 22 21:45:26 2024 user.notice overwatch-initd:: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied Fri Mar 22 21:45:28 2024 user.notice overwatch-initd:: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied Fri Mar 22 21:45:42 2024 user.notice overwatch-initd:: [0;33m[WARNING]: [0mIllegal attempt to suspend fastpath denied Fri Mar 22 21:45:55 2024 daemon.warn odhcpd[2627]: No default route present, overriding ra_lifetime! Fri Mar 22 21:51:16 2024 daemon.warn odhcpd[2627]: No default route present, overriding ra_lifetime! Fri Mar 22 21:52:39 2024 kern.warn kernel: CSIMON: CSIMON[1.1.0] Initialization Fri Mar 22 21:52:39 2024 kern.warn kernel: CSIMON: M2M usr already registered ... Fri Mar 22 21:53:00 2024 kern.warn kernel: CSIMON: CSIMON[1.1.0] Initialization Fri Mar 22 21:53:00 2024 kern.warn kernel: CSIMON: M2M usr already registered ... Fri Mar 22 21:58:05 2024 daemon.warn odhcpd[2627]: No default route present, overriding ra_lifetime! Fri Mar 22 22:00:00 2024 cron.info crond[2662]: USER root pid 4702 cmd echo 3 > /proc/sys/vm/drop_caches Fri Mar 22 22:00:00 2024 kern.info kernel: ash (4702): drop_caches: 3
Administrators Netduma Fraser Posted March 22, 2024 Administrators Posted March 22, 2024 We have a firmware in testing currently that resolves the main issues, if that works as expected it should be out soon Authentik06 1
banjo22 Posted March 22, 2024 Author Posted March 22, 2024 3 minutes ago, Netduma Fraser said: We have a firmware in testing currently that resolves the main issues, if that works as expected it should be out soon Do you know what the problem is here?
Administrators Netduma Fraser Posted March 22, 2024 Administrators Posted March 22, 2024 I'm not a dev so I don't know the details like they do, based on what the logs mention I think we have done some work in those areas so it might help
banjo22 Posted March 28, 2024 Author Posted March 28, 2024 Updated the wrong thread when this happened but luckily saved the log. Same issue happened yesterday around 13:06 / 07. Hopefully helps fix the issue: Wed Mar 27 13:05:33 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:33 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:33 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:33 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:33 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:34 2024 daemon.err cli.lua[4413]: RTNETLINK answers: File exists Wed Mar 27 13:05:38 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:05:40 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:05:40 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:40 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:40 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:40 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:40 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:40 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:45 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:05:48 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:05:48 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:48 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:48 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:48 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:48 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:48 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:50 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:50 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:50 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:50 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:50 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:50 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:51 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:51 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:05:51 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:51 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:51 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:05:51 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:05:52 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:05:57 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:06:11 2024 daemon.err cli.lua[4413]: RTNETLINK answers: No such process Wed Mar 27 13:06:26 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:26 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:26 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:26 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:26 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:26 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:27 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:27 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:27 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:27 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:27 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:27 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:29 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:29 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:30 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:30 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:30 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:30 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:30 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:06:31 2024 daemon.err cli.lua[4413]: RTNETLINK answers: File exists Wed Mar 27 13:06:34 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:06:37 2024 daemon.info dnsmasq-dhcp[4385]: DHCPDISCOVER(br-lan) 44:6d:7f:b2:a2:a3 Wed Mar 27 13:06:37 2024 daemon.info dnsmasq-dhcp[4385]: DHCPOFFER(br-lan) 192.168.1.106 44:6d:7f:b2:a2:a3 Wed Mar 27 13:06:37 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.106 44:6d:7f:b2:a2:a3 Wed Mar 27 13:06:37 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.106 44:6d:7f:b2:a2:a3 Wed Mar 27 13:06:37 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:37 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:37 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:37 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:38 2024 daemon.err cli.lua[4413]: RTNETLINK answers: File exists Wed Mar 27 13:06:38 2024 daemon.err cli.lua[4413]: RTNETLINK answers: File exists Wed Mar 27 13:06:43 2024 daemon.err cli.lua[4413]: RTNETLINK answers: File exists Wed Mar 27 13:06:44 2024 daemon.err cli.lua[4413]: RTNETLINK answers: No such process Wed Mar 27 13:06:44 2024 daemon.err cli.lua[4413]: RTNETLINK answers: No such process Wed Mar 27 13:06:44 2024 daemon.err cli.lua[4413]: RTNETLINK answers: No such process Wed Mar 27 13:06:46 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:46 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:06:46 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:06:46 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:06:46 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:06:49 2024 daemon.err cli.lua[4413]: RTNETLINK answers: No such process Wed Mar 27 13:06:50 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:06:55 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:07:12 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:07:12 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:12 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:12 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:12 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:12 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:12 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:13 2024 daemon.err cli.lua[4413]: RTNETLINK answers: File exists Wed Mar 27 13:07:19 2024 daemon.err cli.lua[4413]: RTNETLINK answers: No such process Wed Mar 27 13:07:32 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:32 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:32 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:32 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:32 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:32 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:34 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:07:35 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:35 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:07:35 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:35 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:35 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:35 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:35 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:43 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:07:54 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:07:56 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:56 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:56 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:56 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:07:56 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:07:58 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:05 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:05 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:05 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:05 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:05 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:05 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:05 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:09 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:21 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:21 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:21 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:21 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:21 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:21 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:21 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:22 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:22 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:22 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:22 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:22 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:22 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:27 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:27 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:27 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:27 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:27 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:29 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:29 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:29 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:29 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:29 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:36 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:36 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:36 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:36 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:08:39 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:44 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:44 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:54 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:54 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:08:54 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:08:54 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:08:54 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:09:02 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:09:13 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:09:27 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:09:27 2024 daemon.info dnsmasq-dhcp[4385]: DHCPREQUEST(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:09:27 2024 daemon.info dnsmasq-dhcp[4385]: DHCPACK(br-lan) 192.168.1.207 76:9f:0e:5f:d4:81 Wed Mar 27 13:09:27 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:09:27 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:09:27 2024 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Mar 27 13:09:27 2024 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Mar 27 13:09:39 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime! Wed Mar 27 13:09:43 2024 daemon.warn odhcpd[2626]: No default route present, overriding ra_lifetime!
Administrators Netduma Fraser Posted March 28, 2024 Administrators Posted March 28, 2024 Could you change the DHCP lease to 10000 please, apply, reboot then see if it happens again?
banjo22 Posted March 30, 2024 Author Posted March 30, 2024 On 3/28/2024 at 4:55 PM, Netduma Fraser said: Could you change the DHCP lease to 10000 please, apply, reboot then see if it happens again? It already is, if I remember correctly; I think I saw that recommended elsewhere, so I changed it a while back.
Administrators Netduma Fraser Posted March 30, 2024 Administrators Posted March 30, 2024 Reserve IPs for the devices in that case and see if it still happens please
