Hi,
I've seen this many times to log it to see if anyone else has experienced it. My game will stop responding for about 5 seconds, then the game will catchup; always online games and only EAFC is affected. I play a lot of COD and have not noticed it on that game.
PS5.
Anything I can check for to prevent it?
For anyone wondering what I mean, see the video I uploaded below:
When I lob passed to the player (Sawa) my game stopped responding, then caught up. I'm assuming something on the network did something at that moment, and when this happens, but I thought the whole point of prioritising traffic is that my PS5 shouldn't be affected by anything else on the network uploading/downloading.
My PS5 is the only device listed in Smartboost, as is Gaming.
For anyone who plays EAFC and Champions this is quite a big issue 😛
Check the ping on the Geo-Filter page when that happens, do you notice it spike up massively? Does the game have an in game ping reading you can enable?
I'll keep an eye on that next time. It happened in the game straight after the one I uploaded.  have turned on ping and connection monitoring within EAFC.
I have someone in the house watching Netflix which is taking a lot of bandwidth, but like I said, everything is set to the PS5 to prioritise for traffic so it shouldn't affect it.
It seems like it's caused by a massive spike in ping so do keep an eye on that. How do you have Congestion Control set? You'll need that setup properly as well to prevent it
Where's congestion control? ANy guides to set that up?
You can find that in Ping Optimizer > Advanced, set it to Always, 70% for download & upload and see if it is better after that
  • 2 weeks later...
For the record I set this. Still happens, only on EAFC. Never has this on the XR1000 ever, it’s becoming unusable.
70% is our recommended starting point but isn't necessarily perfect for everyone, experiment with the percentages to see which works best for you
More I’m playing COD I’m noticed a lot of lag now too. I’ve played around with the percentages, not much is making a difference.
what is the router doing here? My upload is 8mb!
I think COD is having server issues. I have been experiencing packet loss for about the last hour.
Could be the above. That'll be local traffic as it wouldn't be possible to go above your internet speeds
  • 2 weeks later...
This still happens, I know it's devices on the network triggering spikes as I was in a game then when my wife turned on her laptop on and my game stopped responding and  the speed up lag occurred. This NEVER happened on the XR1000 but consistently happens on the R3, so what technology has changed? The whole point with speed boost and prioritising traffic is that it protects me from these other devices.
Is this going to be resolved?
Are you using a hardwired connection? That would help!
Yep. Exact same setup as I had with the XR1000, which had many problems but prioritsing traffic never one of them
The Congestion Control aspect will resolve that so you'll need to experiment with the percentages to find what works best - 70% doesn't work for everyone
Can you explain the percentages please? I played around with them and didn't see much improvement, its also hard to test as its just random spikes
Saturate your connection with downloads while following this guide: https://support.netduma.com/en/support/solutions/articles/16000074717-how-to-test-your-internet-ping It's best to start with a high value for Congestion Control (set on Always), say 95% then do a test, decrease by 10%, test, decrease by 10% etc, until you get to a value that is pretty good and then try 5% either side of that value to see if it can be improved. It's important to note that Download & Upload on Congestion Control don't have to be the same value and that you may have a better experience with differing values.
There is certainly something not right. I have followed that guide. When not flooding the network the ping was consistent at around 20ms. I started downloading and regardless of what I set the % to whilst having 'Always On', on, the NAS (what was downloading)  was using all 30mb of my bandwidth, it never changed from 50% to 90%. (My speeds are 30 down, 7 up) Help!
Just to add to this. I will go into an online EAFC game, start the download going on the NAS again and all 30mb is dedicated to the NAS despite me being in an online game, my PS5 being in devices in Smartboost (the only device) and only having Gaming under priorities. (Always on, on)
Are you using PPPoE/VLAN/IPv6 or DHCP Identifiers? If you disable IPv6 in LAN/WAN do the percentages then take affect?
PppoE. I can try that tonight and report back
Just now, Netduma Fraser said:
Okay keep us posted! Otherwise it might be due to PPPoE
Been pppoe on the R2 and Xr1000…..seems like an easy get out clause to blame that.
 if it’s pppoe then how long do I have to send the r3 back?
Not really an easy one, both of those didn't have QoS working correctly with PPPoE.
I don't know that it is that but its a potential. You can refer to netduma.com/terms for those details
IPv6 was already disabled for the record.
I have emailed about returning the device, not sure what the point of having PPPoE on it if it doesn't work correctly. You mention QOS on the XR1000 but I never had this issue over 2 years using it..
