stejinn7 Posted February 26, 2024 Share Posted February 26, 2024 Hi, I have a problem with the strict mode (with Netgear XR1000 i never had problems like this). i’m actually playing on EA FC 2024 and eFootball 2024, and with both game i have the same problem. If I put custom mode and polygon points in Switzerland, and I search in game, it continue to start also in other areas. i have Ping assist off (but i tried also 0-1ms), strict mode enabled and fast search disabled. i have also filtering enabled on PlayStation but the situation it’s ever the same. i have 4.0.41 version. Waiting for your answer, see u. IMG_7593.mov Link to comment Share on other sites More sharing options...
DARKNESS Posted February 26, 2024 Share Posted February 26, 2024 @stejinn7Disable Geo-latency Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 26, 2024 Administrators Share Posted February 26, 2024 As well as the above try the simple mode instead of polygon. You're also on an older firmware, latest is here: https://forum.netduma.com/topic/53938-new-r3-firmware-4041/ Link to comment Share on other sites More sharing options...
