Mr MuRFiE Posted February 7, 2024 Posted February 7, 2024 I have this message pop up after I check a scheduled connection test. I have not had a new firmware update since this test was done, so not sure what's going on, any insight on this would be greatly appreciated.
Administrators Netduma Fraser Posted February 8, 2024 Administrators Posted February 8, 2024 How long ago was the scheduled test exactly? Have you rebooted or anything since the test was done?
Mr MuRFiE Posted February 8, 2024 Author Posted February 8, 2024 4 hours ago, Netduma Fraser said: How long ago was the scheduled test exactly? Have you rebooted or anything since the test was done? The test was scheduled for every 24 hours, however I reset DumoOS this morning and run a scheduled test after a manual test 1 min later and I got the same message, I have established this occurs on every scheduled test that is run. Still running same firmware on modem and DumaOS Firmware Version 21.4.0439 DumaOS Version 3.3.157
Administrators Netduma Fraser Posted February 8, 2024 Administrators Posted February 8, 2024 Have you disabled QoS by any chance?
Mr MuRFiE Posted February 8, 2024 Author Posted February 8, 2024 2 hours ago, Netduma Fraser said: Have you disabled QoS by any chance? Nope
Administrators Netduma Fraser Posted February 9, 2024 Administrators Posted February 9, 2024 Okay I'll pass this onto the team to see if we can reproduce it, thanks for the report Mr MuRFiE 1
Mr MuRFiE Posted June 8, 2024 Author Posted June 8, 2024 I haven't posted for a while, as most features work, but this issue still exists, any progress on fixing this?
Administrators Netduma Fraser Posted June 8, 2024 Administrators Posted June 8, 2024 I'll check in with the team about this on Monday and get back to you! Mr MuRFiE 1
Administrators Netduma Jack B Posted June 10, 2024 Administrators Posted June 10, 2024 Hi @MuRF FuRY Thanks for the report we've recreated the issue. We'll get a fix for it in the next firmware.
Mr MuRFiE Posted June 10, 2024 Author Posted June 10, 2024 Awesome, thanks for the update. Netduma Fraser 1
