Goodwinn20 Posted February 1, 2024 Share Posted February 1, 2024 After doing the new update it’s not letting me do a speed test and ping optimiser? Does anyone know why this isn’t working? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 1, 2024 Administrators Share Posted February 1, 2024 What do you mean it's not letting you exactly? Link to comment Share on other sites More sharing options...
Goodwinn20 Posted February 1, 2024 Author Share Posted February 1, 2024 Sorted it now had to do a factory reset?! Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 1, 2024 Administrators Share Posted February 1, 2024 Good to hear, there has been quite a few changes so I'd recommend doing it personally Link to comment Share on other sites More sharing options...
mcallisterbr69 Posted February 1, 2024 Share Posted February 1, 2024 The speed test and ping optimiser has never worked for me still buged..... Still waiting for the update that fixes it but not happened yet..... PharmDawgg 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 1, 2024 Administrators Share Posted February 1, 2024 9 minutes ago, mcallisterbr69 said: The speed test and ping optimiser has never worked for me still buged..... Still waiting for the update that fixes it but not happened yet..... We are aware Ping Optimizer/Speed Test isn't 100% reliable at the moment and it's something the team are working on. Those features can still work, it just may not be every time. In the meantime best to adjust Congestion Control manually in Ping Optimizer > Advanced. Link to comment Share on other sites More sharing options...
ddotangel Posted February 1, 2024 Share Posted February 1, 2024 neither has worked for me since i bought the router not even once.. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 1, 2024 Administrators Share Posted February 1, 2024 34 minutes ago, ddotangel said: neither has worked for me since i bought the router not even once.. What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode Link to comment Share on other sites More sharing options...
JRM2011 Posted February 1, 2024 Share Posted February 1, 2024 My r2 (on early access firmware) and r3 speedtest do not work. 2 different isp's. Both modems in ip passthrough. Ping test only works sometimes. Link to comment Share on other sites More sharing options...
Spdsk8race Posted February 1, 2024 Share Posted February 1, 2024 Make sure you have speedboost turned on if you're trying to use ping optimize or speed test. Link to comment Share on other sites More sharing options...
JRM2011 Posted February 1, 2024 Share Posted February 1, 2024 Smartboost? Yeah, it's enabled and it just says "Starting speed test" and spins Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 1, 2024 Administrators Share Posted February 1, 2024 If the server is unavailable it may not work, if you try a few more times it should be successful Link to comment Share on other sites More sharing options...
mstutz2319 Posted February 2, 2024 Share Posted February 2, 2024 2 hours ago, Netduma Fraser said: If the server is unavailable it may not work, if you try a few more times it should be successful What server does it use for speed testing? Mine doesn't work either; AT&T Fiber router in IP Passthrough mode. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 2, 2024 Administrators Share Posted February 2, 2024 9 hours ago, mstutz2319 said: What server does it use for speed testing? Mine doesn't work either; AT&T Fiber router in IP Passthrough mode. It uses measurementlabs, if the main server is down and the backups are down it won't work Link to comment Share on other sites More sharing options...
ddotangel Posted February 2, 2024 Share Posted February 2, 2024 19 hours ago, Netduma Fraser said: What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode i have a netgear cm1200 my connection is cable coax to modem then netduma connected to it and everything connected to the netduma ive not dmz'd anything Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 2, 2024 Administrators Share Posted February 2, 2024 1 hour ago, ddotangel said: i have a netgear cm1200 my connection is cable coax to modem then netduma connected to it and everything connected to the netduma ive not dmz'd anything Do you get an error when trying to run the test at all? Link to comment Share on other sites More sharing options...
ddotangel Posted February 2, 2024 Share Posted February 2, 2024 yeah with speedtest says starting speed test but does nothing then gives 2 lines as my speeds. and on ping optimizer it says starting and does nothing then give same error both in attachments Link to comment Share on other sites More sharing options...
ddotangel Posted February 2, 2024 Share Posted February 2, 2024 21 minutes ago, Netduma Fraser said: Do you get an error when trying to run the test at all? yeah these below both will say starting test but nothing happens no graph or anything then these errors pop up Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 2, 2024 Administrators Share Posted February 2, 2024 28 minutes ago, ddotangel said: yeah these below both will say starting test but nothing happens no graph or anything then these errors pop up Have you factory reset since upgrading to this one? I would recommend it as there has been a lot of changes Link to comment Share on other sites More sharing options...
ddotangel Posted February 2, 2024 Share Posted February 2, 2024 yeah i factory rest twice Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 2, 2024 Administrators Share Posted February 2, 2024 Could you grab the log from when you run it and it fails please? Link to comment Share on other sites More sharing options...
ddotangel Posted February 2, 2024 Share Posted February 2, 2024 yeah, how do i do that? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 2, 2024 Administrators Share Posted February 2, 2024 Go to Settings > Troubleshooting > Advanced Link to comment Share on other sites More sharing options...
ddotangel Posted February 3, 2024 Share Posted February 3, 2024 okay i did heres what it says R3_2024-02-03T01_34_15.266Z_logs.txt Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 3, 2024 Administrators Share Posted February 3, 2024 Thank you, I will pass that onto the team and see if there is anything helpful there. In the meantime change Congestion Control manually in Ping Optimizer > Advanced. Link to comment Share on other sites More sharing options...
