Gemsgolf Posted January 24, 2024 Share Posted January 24, 2024 Can get my computer to the internet via wireless to the net duma R3 but the Hardwire shows connected to the computer but when i shut the wireless off it does not connect on ethernet? Link to comment Share on other sites More sharing options...
DARKNESS Posted January 24, 2024 Share Posted January 24, 2024 Try renewing the dhcp lease on the network settings to clarify am referring to the device your connected to on the lan so it would be on your systems adapter settings. Gemsgolf 1 Link to comment Share on other sites More sharing options...
Fuzy Posted January 24, 2024 Share Posted January 24, 2024 Hi ! These are 2 separate network cards with their own Mac address so normally you should be able to connect both at the same time. Check your yellow port ethernet cable on the R3. Have you modified any parameters on your PC on the ethernet card? Link to comment Share on other sites More sharing options...
Gemsgolf Posted January 24, 2024 Author Share Posted January 24, 2024 no i have not modified Link to comment Share on other sites More sharing options...
Gemsgolf Posted January 24, 2024 Author Share Posted January 24, 2024 Fuzy 1 Link to comment Share on other sites More sharing options...
Gemsgolf Posted January 24, 2024 Author Share Posted January 24, 2024 Link to comment Share on other sites More sharing options...
Gemsgolf Posted January 24, 2024 Author Share Posted January 24, 2024 1 hour ago, DARKNESS said: Try renewing the dhcp lease on the network settings to clarify am referring to the device your connected to on the lan so it would be on your systems adapter settings. Doing this might have worked Link to comment Share on other sites More sharing options...
Gemsgolf Posted January 24, 2024 Author Share Posted January 24, 2024 2 minutes ago, Gemsgolf said: Doing this might have worked So far so good TY Fuzy 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 25, 2024 Administrators Share Posted January 25, 2024 Glad to hear you got it sorted, thanks for the update! Link to comment Share on other sites More sharing options...
