Sleeb Posted January 16, 2024 Share Posted January 16, 2024 Hey, ever since getting the R3 is just have horrible ping spikes all over the place on cod, teamspeak, everywhere really.. Same thing with my jitter, it is way higher than just plugging it into my modem. I have fiber and my jitter would always sit around 0.2 in TS but now its constantly spiking from 1 to 2. Is this a cpu problem on the router or? Any way i can fix this? i have literally everything turned off congestion wise, ping wise etc. tried every setting it's still not what it's supposed to be. Not satisfied with this router whatsoever for now. Bjarne Link to comment Share on other sites More sharing options...
TG3NOC1D3 Posted January 16, 2024 Share Posted January 16, 2024 47 minutes ago, Sleeb said: Hey, ever since getting the R3 is just have horrible ping spikes all over the place on cod, teamspeak, everywhere really.. Same thing with my jitter, it is way higher than just plugging it into my modem. I have fiber and my jitter would always sit around 0.2 in TS but now its constantly spiking from 1 to 2. Is this a cpu problem on the router or? Any way i can fix this? i have literally everything turned off congestion wise, ping wise etc. tried every setting it's still not what it's supposed to be. Not satisfied with this router whatsoever for now. Bjarne Are your spikes only 1 to 2ms in games? If so, that isn't enough to make a major difference in hit detection. I will say, COD is notorious for punishing players who play well, there is an entire article that came out about it. They make it so you constantly feel the need to do better, the more wins, the more they will punish you temporarily, so you come back for that win hit, like a drug. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 16, 2024 Administrators Share Posted January 16, 2024 Yes we believe it is a CPU issue, fixed in a firmware expected this week Link to comment Share on other sites More sharing options...
