12 hours ago, cljackhammer said:
@Chaiyoabcdoes congestion control work properly with IPv6 on .16?
I disabled ipv6 completely. May be that was why everything has been working well idk
UPNP Triggering is so far quite inconsistent even on the current 4.0.23 beta.
What I realise is that even sometimes after rebooting the PC it does not show OPEN NAT even if DUMAOS shows 'Demonware Port Mapping' activated under UPNP when you launch COD.
What I did was to create a manual port forwarding rule for Source Port 3074 TCP/UDP Destination Port : 1-65535 and run it whenever I encounter issues with NAT on COD.
Then once it shows open under NAT in COD, I will exit the game and disable that rule in Port Forwarding.  Restart your PC and it should show OPEN Nat under both game and DUMAOS.
The UPNP to me feels like it is sleeping at times or ignores the port even if it shows it is activated. I hope the way it triggers UPNP will be addressed in the next firmware. Because when it works, it works and when it does not, it is very annoying to do the above just to get it to work. I also feel that rebooting the router some of the settings are not applied properly or needs to be activated again just to get it to take effect.
*** Please ensure both WAN/LAN IPV6 is disabled too. Buggy at the moment... ***
22 hours ago, Netduma Fraser said:
Makes sense thanks!
what is the best way to portfoward im a lil confused
Well what is the ports specifically you want to forward/the range?
well ive done it like the one at the bottom but ive seen others do it like the top pic i was just wondering if there was a right or wrong way of doing this
as its just the port ranges im confused about
    TCP: 3074,3075,27015-27030,27036-27037
    UDP: 3074,4380,27000-27036
4 hours ago, Netduma Fraser said:
I'd do 3 rules, 2 ranges, one singular:
27000 - 27037 TCP & UDP
3074 - 3075 TCP & UDP
4380 UDP
SO LIKE THIS ???
I used to set manual port forward
3074 src 3074 dst
but it always is ‘inactive’ so I kinda assume that pf is not working right now
3074 src 3074 dst
It is working, just showing inactive, we'll fix that
