Derek2626 Posted January 3, 2024 Posted January 3, 2024 Typically when having horrible games I was able to throttle my speeds down on my xr500 using congestion control sliders to get better games…on the r3 it doesn’t allow to go under the 50% mark on congestion control. Is it possible to throttle speeds on the r3 another way?
DARKNESS Posted January 3, 2024 Posted January 3, 2024 @Derek2626Only alternative currently is just changing your speeds which is dumb which is what I said as well about not being allowed to go below 50% as not every network is the same and ideally you want the least amount of buffer for gaming.
Derek2626 Posted January 3, 2024 Author Posted January 3, 2024 yeah, im not a huge fan of the r3 yet. hopefully some firmware updates resolve some issuesd
Administrators Netduma Fraser Posted January 4, 2024 Administrators Posted January 4, 2024 As above, not possible to go below 50% currently but it has been requested so will likely be possible in a future update. If you're having any issues do let us know and we can assist.
