titofuenla Posted January 19, 2024 Share Posted January 19, 2024 20 minutes ago, pyroass said: another thing I notice is the download speed on wifi. even if I only have one device connected to the network at the time it doesn't go over 30mb download. on cable it reaches somewhere around 550MB. With another router I get somewhere between 890-990MB download. Try splitting the 2.4Ghz and 5Ghz bands, see if you get better results Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 19, 2024 Administrators Share Posted January 19, 2024 For WiFi: Split the bands, give 2.4/5GHz different names and apply - you'll want to connect to 5GHz specifically for speeds Use a WiFi analyzer to find the least congested channel and change to that Experiment with the widths to see what gives better results Ensure it's in an elevated position - not on a metal surface Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible Set the antennae to this position _ | | _ Link to comment Share on other sites More sharing options...
pyroass Posted January 19, 2024 Author Share Posted January 19, 2024 seems a bit better but not so much improvement. @Netduma Fraserthe new update you need to send it manually? or will come today directly in the router? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 19, 2024 Administrators Share Posted January 19, 2024 1 hour ago, pyroass said: seems a bit better but not so much improvement. @Netduma Fraserthe new update you need to send it manually? or will come today directly in the router? What speeds are you getting now and with what widths? Not sure yet but still on track for today I think Link to comment Share on other sites More sharing options...
pyroass Posted January 20, 2024 Author Share Posted January 20, 2024 @Netduma Fraseri discovered a new thing. If i'm going to geo-filter, setting and disable geo-latency, i can connect on what server i want. the problem is that the ping will be much higher. like 25-30ms +. if i disable geo-latency and connect on the same server, ms will be fine. Link to comment Share on other sites More sharing options...
VanillaCokeZz Posted January 20, 2024 Share Posted January 20, 2024 My DumaOS UI is laggy when I open it in my browser. I use Opera GX. cheers Link to comment Share on other sites More sharing options...
DanologyUK Posted January 20, 2024 Share Posted January 20, 2024 21 minutes ago, VanillaCokeZz said: My DumaOS UI is laggy when I open it in my browser. I use Opera GX. cheers Is it laggy in any other browser? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 20, 2024 Administrators Share Posted January 20, 2024 2 hours ago, pyroass said: @Netduma Fraseri discovered a new thing. If i'm going to geo-filter, setting and disable geo-latency, i can connect on what server i want. the problem is that the ping will be much higher. like 25-30ms +. if i disable geo-latency and connect on the same server, ms will be fine. Is this server inside or outside your radius? Is this with Steady Ping disabled or enabled? 1 hour ago, VanillaCokeZz said: My DumaOS UI is laggy when I open it in my browser. I use Opera GX. cheers I'm using Opera GX and it is fine for me, make sure to disable the Adblocker for the page, you may need to clear browser cache/cookies as well then refresh each page on the interface once and it'll be faster then. Link to comment Share on other sites More sharing options...
pyroass Posted January 20, 2024 Author Share Posted January 20, 2024 @Netduma Fraser inside of my radius. steady ping disabled. even if i enable or disable steady ping i will have the same ping from today. it is very wierd. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 20, 2024 Administrators Share Posted January 20, 2024 1 hour ago, pyroass said: @Netduma Fraser inside of my radius. steady ping disabled. even if i enable or disable steady ping i will have the same ping from today. it is very wierd. Is it the exact same server as in the IDs for it match? Link to comment Share on other sites More sharing options...
pyroass Posted January 20, 2024 Author Share Posted January 20, 2024 what do you mean with IDs for the match? i don't get it 10 minutes ago, Netduma Fraser said: Is it the exact same server as in the IDs for it match? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 20, 2024 Administrators Share Posted January 20, 2024 When you ping a server there is a server ID Link to comment Share on other sites More sharing options...
pyroass Posted January 20, 2024 Author Share Posted January 20, 2024 Yes, it's the same Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 21, 2024 Administrators Share Posted January 21, 2024 Okay thanks, I'll pass that onto the team Link to comment Share on other sites More sharing options...
pyroass Posted January 22, 2024 Author Share Posted January 22, 2024 @Netduma Fraserseems my ping is back to normal. pretty wierd. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 22, 2024 Administrators Share Posted January 22, 2024 2 hours ago, pyroass said: @Netduma Fraserseems my ping is back to normal. pretty wierd. Perhaps a one off then, do keep us updated if it happens again, the new firmware should only help with it Link to comment Share on other sites More sharing options...
pyroass Posted January 22, 2024 Author Share Posted January 22, 2024 2 hours ago, Netduma Fraser said: Perhaps a one off then, do keep us updated if it happens again, the new firmware should only help with it the new firmware it is realease? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 22, 2024 Administrators Share Posted January 22, 2024 2 hours ago, pyroass said: the new firmware it is realease? No yet, will be this week from what I've been told Link to comment Share on other sites More sharing options...
pyroass Posted January 25, 2024 Author Share Posted January 25, 2024 On 1/22/2024 at 5:17 PM, Netduma Fraser said: No yet, will be this week from what I've been told Hello @Netduma Fraser, do you have an update about firmware upgrade? thank you! Nalsano_ 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 25, 2024 Administrators Share Posted January 25, 2024 1 hour ago, pyroass said: Hello @Netduma Fraser, do you have an update about firmware upgrade? thank you! Still on track from what I've been told Link to comment Share on other sites More sharing options...
pyroass Posted January 26, 2024 Author Share Posted January 26, 2024 @Netduma Fraseri saw if i have my device add in geo filter i cannot watch if someone it's sharing the screen on PS5. if i remove the device and turn off geo filter will work normally. Link to comment Share on other sites More sharing options...
