need help EA FC 24 ping improuve with R3
Authentik06
 Share
1 hour ago, Authentik06 said:
Can any one help me i’ m really frustrated
have the best router in the world and didn’t improve my internet 😕
will take the controle if you want
Wait for Fraser to pop along.
bit of advice, don’t allow anyone to take control of your pc or into your network. Be safe online.
Yes have my pc and some devices connected but smart boost is activated and gaming fully  priority and i have found when i’am playing smart boost showing gaming was offline
Some devices, does that mean some are connected to the ISP modem/router? How have you set that up to pass traffic to the R3? How have you set Congestion Control?
30 minutes ago, Netduma Fraser said:
Certains appareils, cela signifie-t-il que certains sont connectés au modem/routeur du FAI ? Comment avez-vous configuré cela pour transmettre le trafic vers le R3 ? Comment avez-vous configuré le contrôle de la congestion ?
All my devices are connected in R3 have turn off wifi ips modem and in qos have juste gaming priorities
14 minutes ago, Netduma Fraser said:
Is it in modem/bridge mode or have you put the R3 in its DMZ? You'll need to do one of those for the optimum connection.
Congestion Control is in Ping Optimizer > Advanced
Its in dmz in modem ISP > DMZ > R3
in ping optimizer the ping stay in 21 it said no optimization required
I'd still suggest changing Congestion Control, try 70% and see if it is any better
I'll take the time to explain everything
i'll start with the XR500 : ea fc 24 : NO JITTER, LOSS ~ 1% gameplay not stable heavy sometimes rapid matches don't look the same !
with the R3 incredibly fluid gameplay i've tested several servers ( france, spain , london , zirich ) even if the ping differs but the gameplay remains almost the same no remarkable difference fluid the players respond to commands on the other hand i have jitter on every match ping a little higher on the R3 and loss also higher
so what annoys me is to see the photos attached the ping to the host is so low but on the lobby and in game x is almost double that I have someone can explain to me what is due to this?
I also play MW 29 MS no LOSS though
so if anyone can enlighten us I'm a taker
On 12/30/2023 at 3:02 AM, Authentik06 said:
What is ( ping plotter) that can you explain me ?
have checked mtu too but in mw3 have no jitter all geo filter activated
yesterday have catastrophic result but game has so smooth can’t explain search for logic reasons 😕 no one !
the jitter Ith xr 500 was null 0 or minim 0.01
but now more than 1%
so what can i do
 and why the ping in duma os and the ping in game was so different 😕
Ping plotter is a program you download from the Internet. It's a program you should get familiar with. It shows your ping from your router or modem, and it shows all the other hops, or nodes that your Internet connects to. If you can share a screen shot of that it would be nice.
Yes i will so what i will do i’v already download it
For example here is my connection when it's good, and when it's bad. Important thing here is the round trip average.IMG_20201225_125252.thumb.jpg.12b46f5b50e1d43b7821cca8994ced63.jpgIMG_20200509_224035.thumb.jpg.74e9d4c8fc37c526f113bc1004c026ba.jpg
3 minutes ago, Netduma Fraser said:
Je veux dire que vous avez envoyé une requête ping au serveur de jeu alors que vous étiez connecté au R3. Alors, pendant que vous êtes connecté à votre modem, faites-le sur le serveur de jeu
Okay w’ll do it now
Thanks for that, it could be related to another issue we're looking at.
In the meantime, try this, remove the console from the Geo-Filter and in the Device Manager change it to a PC then re-add it to the Geo-Filter, does it work better then?
@Netduma FraserJe le ferai en rentrant chez moi
Par contre j'ai remarqué une chose justement quand on fait les appareils en PC les paramètres répondent mieux et les supportent mieux par exemple dans le tableau de bord les heures de jeu sont comptées juste pour le pc, Je pense que comme tu dis, il existe un moyen qui fonctionne
Je ne peux pas attendre le test
Il y a 4 heures, Netduma Fraser a dit :
Merci pour cela, cela pourrait être lié à un autre problème que nous étudions.
En attendant, essayez ceci, supprimez la console du Geo-Filter et dans le Gestionnaire de périphériques, changez-la en PC puis rajoutez-la à nouveau au Geo-Filter, est-ce que ça fonctionne mieux alors
I'll try this as well, see if I notice any difference.
On 12/25/2023 at 10:55 PM, Lyuboosik said:
This is strange. I play EA FC, 15-20ms. Just geo filter on, steady ping turned OFF.  because for Fifa you don't need steady ping. Been using netduma for years for competitive Fifa. If it wasn't for Duma I probably wouldn't be #1 in the world.
Do you ever suffer with crazy heavy input delay? Here in the UK especially the London server it’s horrible night or day. How do you fix this?
 Share
