How are you selecting specific servers exactly? Are the servers it is connecting to outside your radius/polygon?
Could you clarify what you mean by this please? "also after cheating the ping make and then going back to geo filter and customising to them locating still not working ?"
It's likely the ping has increased due to Steady Ping, this feature increases your ping to create a buffer so that any spikes/fluctuations are absorbed by this buffer, giving you one consistent ping throughout the entire game that doesn't change which should give you a smoother experience.
The TP link is that a powerline adapter you're using or is it another router with devices connected to it?
Hello @Goodwinn20
 If @Netduma Fraser doesnt respond to your PM make sure to come back here and try the forum.. Its always better to post on the support forum to get a quicker response..
Thanks!
Zippy.
Best to respond on the forum, I am getting so many DMs at the moment that it is highly likely I will miss it.
Are the TP Links powerline adapters or are they routers as well?
