spoiledbythe90s Posted December 19, 2023 Posted December 19, 2023 Hello, I literally just unboxed my XR1000. Set it up correctly, but my QOS doesn’t show up at all nor does my Geo-Filter accept my location. The 1st pic is the message I keep getting when I click on the QOS tab. The 2nd pic is what I see when I try to set my geo-filter. I’ve had Netgear routers for years so I know this is typically a smooth process. Just recently switched back to Netgear from ASUS. As soon as I plugged it, these are the messages that I’m seeing. Any solution?
DARKNESS Posted December 19, 2023 Posted December 19, 2023 @spoiledbythe90sDo a hard reset and then don't enable the shield and use incognito as it doesn't save cache and conflict with OS
Administrators Netduma Fraser Posted December 19, 2023 Administrators Posted December 19, 2023 Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, close the tab, then wait 4 minutes before accessing and see if the page loads. Don't use Armor, make sure you're accessing the interface using HTTP not HTTPS and if you have a browser based Adblocker disable it and see if the Geo works please.
spoiledbythe90s Posted December 22, 2023 Author Posted December 22, 2023 Thank you! That appeared to work; however, I'm unsure if the geo filter is working. I know with my previous Netduma routers, once you enabled the filter, to play with players outside of your radius, you had to select them/grant permissions manually. Now, it appears I can party up with anyone no matter where they are without granting permission. I'm not mad about that in any way shape or form since it takes away added work, but I just wanted to know if that's normal and if the filter is still working?
Administrators Netduma Fraser Posted December 22, 2023 Administrators Posted December 22, 2023 1 hour ago, spoiledbythe90s said: Thank you! That appeared to work; however, I'm unsure if the geo filter is working. I know with my previous Netduma routers, once you enabled the filter, to play with players outside of your radius, you had to select them/grant permissions manually. Now, it appears I can party up with anyone no matter where they are without granting permission. I'm not mad about that in any way shape or form since it takes away added work, but I just wanted to know if that's normal and if the filter is still working? Doesn't sound like it's working properly, could you provide a screenshot of the Geo-Filter page please?
spoiledbythe90s Posted December 22, 2023 Author Posted December 22, 2023 I can never get it to stay on for long for some reason. It stays on this screen for majority of the time although I’m still connected to the internet.
spoiledbythe90s Posted December 22, 2023 Author Posted December 22, 2023 When it does connect, this is what I see
Administrators Netduma Fraser Posted December 22, 2023 Administrators Posted December 22, 2023 If you get that disconnect issue try accessing using 192.168.1.1 instead. From the Geo-Filter screenshot it appears to be working as expected, authentication server in Ireland is allowed which is normal/needed and anything within the radius is allowed. Nothing else is outside the radius so all good!
spoiledbythe90s Posted December 22, 2023 Author Posted December 22, 2023 Ok! Thank you! Greatly appreciate you guys! Netduma Fraser 1
