clarkjo Posted December 19, 2023 Share Posted December 19, 2023 basically the title, when I woke up my PC it would instantly connect to ethernet on my old netgear router, but with the R3 it's taking about 30 seconds just to connect. any fix? oldman66 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 19, 2023 Administrators Share Posted December 19, 2023 I've sent you a private message, please check there Link to comment Share on other sites More sharing options...
Mr_Meeseeks Posted December 19, 2023 Share Posted December 19, 2023 3 hours ago, Netduma Fraser said: I've sent you a private message, please check there I’m haveing the same issue can you please help me Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 19, 2023 Administrators Share Posted December 19, 2023 1 hour ago, Mr_Meeseeks said: I’m haveing the same issue can you please help me I have PMd you Link to comment Share on other sites More sharing options...
simjc Posted December 19, 2023 Share Posted December 19, 2023 I assume this is a known issue, and a fix is on the way. I am also experiencing this with my Xbox Series X, from standby it takes 30secs or so for it to connect to the Internet via an ethernet cable. With R2 it was instant. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 19, 2023 Administrators Share Posted December 19, 2023 This is the first time it has been reported but there was a fix in a firmware which I thought may help with this simjc 1 Link to comment Share on other sites More sharing options...
Mr_Meeseeks Posted December 19, 2023 Share Posted December 19, 2023 2 hours ago, Netduma Fraser said: This is the first time it has been reported but there was a fix in a firmware which I thought may help with this the firmware did not fix this issue simjc 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 19, 2023 Administrators Share Posted December 19, 2023 Thanks for trying, I will pass it onto the team to have a look at, is it Windows 7, 10, 11 you're using? Link to comment Share on other sites More sharing options...
Mr_Meeseeks Posted December 20, 2023 Share Posted December 20, 2023 13 hours ago, Netduma Fraser said: Thanks for trying, I will pass it onto the team to have a look at, is it Windows 7, 10, 11 you're using? windows 11 home edition Link to comment Share on other sites More sharing options...
John R3 For Me Posted December 20, 2023 Share Posted December 20, 2023 I see this same problem when I start my Xbox.. also can you please post a video showing how to port forward the R3 for my Xbox.. Thanks Link to comment Share on other sites More sharing options...
simjc Posted December 20, 2023 Share Posted December 20, 2023 To provide more info this issue also happens with a win10 laptop (ethernet connected, ipv6 disabled on R3) when put to sleep, approx 15secs or so, and appears to be related to log entries w.r.t. port of interest entering a learning state. Specifics firmware 4.0.19: Chrome Web browser: tab1 = dumaos, tab2 = sat with a new.bbc.co.uk entered into url but not executed, i.e. blank tab Put laptop to sleep R3 Eth1 port (laptop connected) goes down, and then disabled Wake up laptop, and press enter on the web url tab to get news... ~15secs delay meanwhile... logs state R1 Eth1 reports Link up... auto negotiates... 10Mbps... 1000Mbps Enters blocked... listening... learning... forwarding state Daemons running on R3 throw errors: ndhttpd, odhcp6c This issue is repeatable, with similar errors both times. See log extract below. Eth1 = laptop, Eth3 = xbox Sim Quote Wed Dec 20 19:00:00 2023 cron.info crond[2658]: USER root pid 31624 cmd echo 3 > /proc/sys/vm/drop_caches Wed Dec 20 19:00:00 2023 kern.info kernel: ash (31624): drop_caches: 3 Wed Dec 20 19:00:25 2023 daemon.err odhcp6c[4846]: Failed to send SOLICIT message to ff02::1:2 (Cannot assign requested address) Wed Dec 20 19:00:29 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link DOWN. Wed Dec 20 19:00:29 2023 kern.info kernel: br-lan: port 1(eth1) entered disabled state Wed Dec 20 19:00:29 2023 daemon.notice netifd: Network device 'eth1' link is down Wed Dec 20 19:00:32 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link Up at 10 mbps full duplex Wed Dec 20 19:00:32 2023 kern.info kernel: br-lan: port 1(eth1) entered blocking state Wed Dec 20 19:00:32 2023 kern.info kernel: br-lan: port 1(eth1) entered listening state Wed Dec 20 19:00:32 2023 daemon.notice netifd: Network device 'eth1' link is up Wed Dec 20 19:00:40 2023 kern.info kernel: br-lan: port 1(eth1) entered learning state Wed Dec 20 19:00:41 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link DOWN. Wed Dec 20 19:00:41 2023 daemon.notice netifd: Network device 'eth1' link is down Wed Dec 20 19:00:41 2023 kern.info kernel: br-lan: port 1(eth1) entered disabled state Wed Dec 20 19:00:44 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link Up at 1000 mbps full duplex Wed Dec 20 19:00:44 2023 kern.info kernel: br-lan: port 1(eth1) entered blocking state Wed Dec 20 19:00:44 2023 kern.info kernel: br-lan: port 1(eth1) entered listening state Wed Dec 20 19:00:44 2023 daemon.notice netifd: Network device 'eth1' link is up Wed Dec 20 19:00:53 2023 kern.info kernel: br-lan: port 1(eth1) entered learning state Wed Dec 20 19:01:01 2023 kern.info kernel: br-lan: port 1(eth1) entered forwarding state Wed Dec 20 19:01:01 2023 kern.info kernel: br-lan: topology change detected, propagating Wed Dec 20 19:01:01 2023 daemon.info dnsmasq-dhcp[6284]: DHCPREQUEST(br-lan) 192.168.77.180 <laptop mac> Wed Dec 20 19:01:01 2023 daemon.info dnsmasq-dhcp[6284]: DHCPACK(br-lan) 192.168.77.180 <laptop mac> SimsI5laptop Wed Dec 20 19:01:01 2023 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Dec 20 19:01:01 2023 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Dec 20 19:01:01 2023 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Dec 20 19:01:01 2023 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Dec 20 19:01:03 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.systeminfo/rpc/: not found Wed Dec 20 19:01:39 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link DOWN. Wed Dec 20 19:01:39 2023 daemon.notice netifd: Network device 'eth1' link is down Wed Dec 20 19:01:39 2023 kern.info kernel: br-lan: port 1(eth1) entered disabled state Wed Dec 20 19:01:41 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link Up at 10 mbps full duplex Wed Dec 20 19:01:41 2023 kern.info kernel: br-lan: port 1(eth1) entered blocking state Wed Dec 20 19:01:41 2023 kern.info kernel: br-lan: port 1(eth1) entered listening state Wed Dec 20 19:01:41 2023 daemon.notice netifd: Network device 'eth1' link is up Wed Dec 20 19:01:46 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link DOWN. Wed Dec 20 19:01:46 2023 daemon.notice netifd: Network device 'eth1' link is down Wed Dec 20 19:01:46 2023 kern.info kernel: br-lan: port 1(eth1) entered disabled state Wed Dec 20 19:01:48 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link Up at 1000 mbps full duplex Wed Dec 20 19:01:48 2023 kern.info kernel: br-lan: port 1(eth1) entered blocking state Wed Dec 20 19:01:48 2023 kern.info kernel: br-lan: port 1(eth1) entered listening state Wed Dec 20 19:01:48 2023 daemon.notice netifd: Network device 'eth1' link is up Wed Dec 20 19:01:57 2023 kern.info kernel: br-lan: port 1(eth1) entered learning state Wed Dec 20 19:02:05 2023 kern.info kernel: br-lan: port 1(eth1) entered forwarding state Wed Dec 20 19:02:05 2023 kern.info kernel: br-lan: topology change detected, propagating Wed Dec 20 19:02:06 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: sa.bbc.co.uk Wed Dec 20 19:02:07 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: mybbc-analytics.files.bbci.co.uk Wed Dec 20 19:02:07 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: mybbc-analytics.files.bbci.co.uk Wed Dec 20 19:02:07 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: mybbc-analytics.files.bbci.co.uk Wed Dec 20 19:02:08 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: uk-script.dotmetrics.net Wed Dec 20 19:02:08 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: uk-script.dotmetrics.net Wed Dec 20 19:02:08 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: uk-script.dotmetrics.net Wed Dec 20 19:02:08 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: static.chartbeat.com Wed Dec 20 19:02:08 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: static.chartbeat.com Wed Dec 20 19:02:08 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: static.chartbeat.com Wed Dec 20 19:02:14 2023 daemon.err odhcp6c[4846]: Failed to send SOLICIT message to ff02::1:2 (Cannot assign requested address) Wed Dec 20 19:02:37 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.settings/rpc/: not found Wed Dec 20 19:04:20 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.pingheatmap/rpc/: not found Wed Dec 20 19:04:22 2023 daemon.err odhcp6c[4846]: Failed to send SOLICIT message to ff02::1:2 (Cannot assign requested address) Wed Dec 20 19:04:28 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.procmanager/rpc/: not found Wed Dec 20 19:04:29 2023 daemon.err ndhttpd[2827]: sh: syntax error: unterminated quoted string Wed Dec 20 19:04:33 2023 user.err datahistory: snapshot.c:117 BUG: last_tx > tx OR last_rx > rx (0 > 0 OR 1133 > 73) Wed Dec 20 19:05:03 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.config/rpc/: not found Wed Dec 20 19:05:09 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.systeminfo/rpc/: not found Wed Dec 20 19:05:09 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.systeminfo/rpc/: not found Wed Dec 20 19:06:21 2023 daemon.err odhcp6c[4846]: Failed to send SOLICIT message to ff02::1:2 (Cannot assign requested address) Wed Dec 20 19:08:20 2023 daemon.err odhcp6c[4846]: Failed to send SOLICIT message to ff02::1:2 (Cannot assign requested address) Wed Dec 20 19:10:27 2023 daemon.err odhcp6c[4846]: Failed to send SOLICIT message to ff02::1:2 (Cannot assign requested address) Wed Dec 20 19:10:58 2023 daemon.err ndhttpd[2827]: sh: �: not found Wed Dec 20 19:10:59 2023 daemon.err ndhttpd[2827]: sh: f: not found Wed Dec 20 19:11:00 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.geofilter/rpc/: not found Wed Dec 20 19:11:00 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.antijitter/rpc/: not found Wed Dec 20 19:11:01 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.config/rpc/: not found Wed Dec 20 19:11:01 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.desktop/rpc/: not found Wed Dec 20 19:11:01 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.procmanager/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.settings/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.smartqos/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: �: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.datahistory/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: �: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: Ӓ: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.datahistory/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.devicemanager/rpc/: not found Wed Dec 20 19:11:02 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.devicemanager/rpc/: not found Wed Dec 20 19:11:03 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.ctwatch/rpc/: not found Wed Dec 20 19:11:11 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.systeminfo/rpc/: not found Wed Dec 20 19:11:54 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link DOWN. Wed Dec 20 19:11:54 2023 kern.info kernel: br-lan: port 1(eth1) entered disabled state Wed Dec 20 19:11:54 2023 daemon.notice netifd: Network device 'eth1' link is down Wed Dec 20 19:11:56 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link Up at 10 mbps full duplex Wed Dec 20 19:11:56 2023 kern.info kernel: br-lan: port 1(eth1) entered blocking state Wed Dec 20 19:11:56 2023 kern.info kernel: br-lan: port 1(eth1) entered listening state Wed Dec 20 19:11:56 2023 daemon.notice netifd: Network device 'eth1' link is up Wed Dec 20 19:12:02 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link DOWN. Wed Dec 20 19:12:02 2023 daemon.notice netifd: Network device 'eth1' link is down Wed Dec 20 19:12:02 2023 kern.info kernel: br-lan: port 1(eth1) entered disabled state Wed Dec 20 19:12:05 2023 kern.crit kernel: eth1 (Ext switch port: 3) (Logical Port: 11) (phyId: 3) Link Up at 1000 mbps full duplex Wed Dec 20 19:12:05 2023 kern.info kernel: br-lan: port 1(eth1) entered blocking state Wed Dec 20 19:12:05 2023 kern.info kernel: br-lan: port 1(eth1) entered listening state Wed Dec 20 19:12:05 2023 daemon.notice netifd: Network device 'eth1' link is up Wed Dec 20 19:12:13 2023 kern.info kernel: br-lan: port 1(eth1) entered learning state Wed Dec 20 19:12:20 2023 daemon.err odhcp6c[4846]: Failed to send SOLICIT message to ff02::1:2 (Cannot assign requested address) Wed Dec 20 19:12:21 2023 kern.info kernel: br-lan: port 1(eth1) entered forwarding state Wed Dec 20 19:12:21 2023 kern.info kernel: br-lan: topology change detected, propagating Wed Dec 20 19:12:24 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: sa.bbc.co.uk Wed Dec 20 19:12:24 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: sa.bbc.co.uk Wed Dec 20 19:12:24 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: mybbc-analytics.files.bbci.co.uk Wed Dec 20 19:12:24 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: mybbc-analytics.files.bbci.co.uk Wed Dec 20 19:12:24 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: mybbc-analytics.files.bbci.co.uk Wed Dec 20 19:12:25 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: uk-script.dotmetrics.net Wed Dec 20 19:12:25 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: uk-script.dotmetrics.net Wed Dec 20 19:12:25 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: uk-script.dotmetrics.net Wed Dec 20 19:12:25 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: static.chartbeat.com Wed Dec 20 19:12:25 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: static.chartbeat.com Wed Dec 20 19:12:25 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: static.chartbeat.com Wed Dec 20 19:12:25 2023 daemon.err ndhttpd[2827]: sh: syntax error: unterminated quoted string Wed Dec 20 19:12:29 2023 daemon.err ndhttpd[2827]: sh: �: not found Wed Dec 20 19:12:30 2023 daemon.err ndhttpd[2827]: sh: f: not found Wed Dec 20 19:12:31 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.geofilter/rpc/: not found Wed Dec 20 19:12:31 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.antijitter/rpc/: not found Wed Dec 20 19:12:31 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.config/rpc/: not found Wed Dec 20 19:12:31 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.desktop/rpc/: not found Wed Dec 20 19:12:32 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.procmanager/rpc/: not found Wed Dec 20 19:12:32 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:12:32 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.settings/rpc/: not found Wed Dec 20 19:12:32 2023 daemon.err ndhttpd[2827]: sh: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:12:32 2023 daemon.err ndhttpd[2827]: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:12:32 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:12:32 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.led-controller/rpc/: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.datahistory/rpc/: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: �: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: �: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: Ӓ: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.datahistory/rpc/: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.devicemanager/rpc/: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.ctwatch/rpc/: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.smartqos/rpc/: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.smartqos/rpc/: not found Wed Dec 20 19:12:33 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.smartqos/rpc/: not found Wed Dec 20 19:12:38 2023 daemon.err ndhttpd[2827]: sh: /www/apps/com.netdumasoftware.systeminfo/rpc/: not found Link to comment Share on other sites More sharing options...
simjc Posted December 20, 2023 Share Posted December 20, 2023 Additional logs for the Xbox perspective demonstrating that 20sec delay to getting online... from learning state until DCHP xbox series x... it shows the period of time before internet is established Quote Wed Dec 20 19:58:32 2023 kern.crit kernel: eth3 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link Up at 1000 mbps full duplex Wed Dec 20 19:58:32 2023 kern.info kernel: br-lan: port 3(eth3) entered blocking state Wed Dec 20 19:58:32 2023 kern.info kernel: br-lan: port 3(eth3) entered listening state Wed Dec 20 19:58:32 2023 daemon.notice netifd: Network device 'eth3' link is up Wed Dec 20 19:58:35 2023 kern.crit kernel: eth3 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link DOWN. Wed Dec 20 19:58:35 2023 kern.info kernel: br-lan: port 3(eth3) entered disabled state Wed Dec 20 19:58:35 2023 daemon.notice netifd: Network device 'eth3' link is down Wed Dec 20 19:58:39 2023 kern.crit kernel: eth3 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link Up at 1000 mbps full duplex Wed Dec 20 19:58:39 2023 kern.info kernel: br-lan: port 3(eth3) entered blocking state Wed Dec 20 19:58:39 2023 kern.info kernel: br-lan: port 3(eth3) entered listening state Wed Dec 20 19:58:39 2023 daemon.notice netifd: Network device 'eth3' link is up Wed Dec 20 19:58:47 2023 kern.info kernel: br-lan: port 3(eth3) entered learning state Wed Dec 20 19:58:55 2023 kern.info kernel: br-lan: port 3(eth3) entered forwarding state Wed Dec 20 19:58:55 2023 kern.info kernel: br-lan: topology change detected, propagating Wed Dec 20 19:59:07 2023 daemon.info dnsmasq-dhcp[6284]: DHCPDISCOVER(br-lan) <XBOX MAC ADDRESS HERE> Wed Dec 20 19:59:07 2023 daemon.info dnsmasq-dhcp[6284]: DHCPOFFER(br-lan) 192.168.77.150 <XBOX MAC ADDRESS HERE> Wed Dec 20 19:59:07 2023 daemon.info dnsmasq-dhcp[6284]: DHCPREQUEST(br-lan) 192.168.77.150 <XBOX MAC ADDRESS HERE> Wed Dec 20 19:59:07 2023 daemon.info dnsmasq-dhcp[6284]: DHCPACK(br-lan) 192.168.77.150 <XBOX MAC ADDRESS HERE> SERIES-X Wed Dec 20 19:59:07 2023 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Dec 20 19:59:07 2023 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Dec 20 19:59:07 2023 user.info com.netdumasoftware.neighwatch: DHCP old event. Wed Dec 20 19:59:07 2023 user.info com.netdumasoftware.neighwatch: DHCP lease change. Wed Dec 20 19:59:16 2023 daemon.warn dnsmasq[6284]: possible DNS-rebind attack detected: aka-cdn.adtech.de Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 21, 2023 Administrators Share Posted December 21, 2023 Thank you for the extra information, I will pass that onto the team simjc 1 Link to comment Share on other sites More sharing options...
Mr_Meeseeks Posted January 3, 2024 Share Posted January 3, 2024 same issue on firmware version 4.0.23 Disrek 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 4, 2024 Administrators Share Posted January 4, 2024 21 hours ago, Mr_Meeseeks said: same issue on firmware version 4.0.23 We're aware of the issue and looking into it Link to comment Share on other sites More sharing options...
clarkjo Posted January 15, 2024 Author Share Posted January 15, 2024 any updates on this? had the router for close to a month now but the issue is still here on latest firmware Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 15, 2024 Administrators Share Posted January 15, 2024 Probably this week if I had to guess. It's important to note, fixes probably won't all come in the same firmware Disrek 1 Link to comment Share on other sites More sharing options...
iOrcus Posted January 16, 2024 Share Posted January 16, 2024 On 12/18/2023 at 8:53 PM, clarkjo said: basically the title, when I woke up my PC it would instantly connect to ethernet on my old netgear router, but with the R3 it's taking about 30 seconds just to connect. any fix? i have the SAME issue. I cant wait for this new update to fix ALL these issues Link to comment Share on other sites More sharing options...
bruistopher Posted January 21, 2024 Share Posted January 21, 2024 New to Netduma. Awesome device but I’m experiencing the same issue from wake up. Battle.net times out and I have to constantly type in my password from PC wake up. I hope we get a fix soon ! Link to comment Share on other sites More sharing options...
TxFrog33 Posted January 21, 2024 Share Posted January 21, 2024 I am also having the exact same issue Really hoping for some good fixes in the newest firmware. is there anything I can do in the mean time? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted January 21, 2024 Administrators Share Posted January 21, 2024 I'm not sure when a fix will be if it'll be in the next one or not but as far as I can tell there isn't anything you can do about it - I have the same issue as well, just have to wait for the 30 seconds Link to comment Share on other sites More sharing options...
eggsmell Posted May 27, 2024 Share Posted May 27, 2024 sorry to necro but still having this issue on 4.0.209, any updates/fixes? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 27, 2024 Administrators Share Posted May 27, 2024 29 minutes ago, eggsmell said: sorry to necro but still having this issue on 4.0.209, any updates/fixes? Try the latest in Early Access, if it's still an issue let us know and I'll pass it onto the team Link to comment Share on other sites More sharing options...
scaryp Posted June 2, 2024 Share Posted June 2, 2024 I'm still seeing the 20-30 delay with Xbox series x before the network is ready on latest R3 firmware. Any fixes, workaround? Tried all sorts of combos from DHCP, reservation, static IP on Xbox, all have same result and it taking 30secs before it's got an IP and on network. Thanks Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted June 2, 2024 Administrators Share Posted June 2, 2024 Okay thanks for letting us know, I'll bump the team to try and get this sorted for the next one. No specific workaround I know of at the moment Link to comment Share on other sites More sharing options...
