SpookyRaider Posted December 18, 2023 Share Posted December 18, 2023 Link to comment Share on other sites More sharing options...
SpookyRaider Posted December 18, 2023 Author Share Posted December 18, 2023 Btw I’m hardwired to my pc. Link to comment Share on other sites More sharing options...
SamT98 Posted December 18, 2023 Share Posted December 18, 2023 Don’t reboot, you need to switch it off and pull the power cable out. Wait 5 min then turn it back on. Will fix itself, I had the exact same issue Link to comment Share on other sites More sharing options...
SpookyRaider Posted December 18, 2023 Author Share Posted December 18, 2023 Ok I’ll try that now… I assume your referring to powering down just the router with the button and waiting 5mins? Tried that and still will not work Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 18, 2023 Administrators Share Posted December 18, 2023 Skip it, complete the Setup Wizard and you can redo it on the main interface or enter your expected speeds manually if its still not working PharmDawgg 1 Link to comment Share on other sites More sharing options...
liluziflirtttt Posted December 18, 2023 Share Posted December 18, 2023 its been doing for 10min already, I wasnt able to do my speedtest nor the ping optimizer PharmDawgg 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 18, 2023 Administrators Share Posted December 18, 2023 14 minutes ago, liluziflirtttt said: its been doing for 10min already, I wasnt able to do my speedtest nor the ping optimizer I have sent you a private message with the solution Link to comment Share on other sites More sharing options...
