Paddee1987 Posted November 13, 2023 Posted November 13, 2023 hi there, is it possible to vpn certian programs on my pc. i want to vpn plex media server, utorrent, opera browser and bluestacks emulator TIA
Administrators Netduma Fraser Posted November 13, 2023 Administrators Posted November 13, 2023 Some of those programs may be listed but otherwise no unless you know the specific ports they're using
Paddee1987 Posted November 13, 2023 Author Posted November 13, 2023 thanks for your reply is there a way to find out the specfic ports used? cheers
Administrators Netduma Fraser Posted November 13, 2023 Administrators Posted November 13, 2023 You have to look online at their respective websites or some people may have worked it out but there is no specific way to find out using the router
