STROXS88 Posted October 14, 2023 Posted October 14, 2023 BELOW I WILL LEAVE SOME THINGS FOR THE DUMAOS ENGINEERS TO TAKE INTO ACCOUNT FOR 3 YEARS TO FIX THE 3 PROBLEMS THAT SINCE DAY ONE I HAVE OWNED THIS ROUTER 1 THE STABILITY WITH THE 5GHZ WIFI) I CAN'T BELIEVE THAT A ROUTER HAS SO BAD STABILITY WITH THE 5GHZ WIFI. I HAVE HAD IT SINCE I HAVE IT, IT IS A 5 GHZ BAND. DOWNLOAD IT SEEMS LIKE IT WAS NOT A 5GHZ, IT IS LIKE IT WAS A 0.0.0.0.05.MHZ AND IT IS A GREAT PROBLEM 2 THE OVERHEATING OF THE ROUTER I DON'T KNOW IF THIS GUY HAS TESTERS WHO DON'T KNOW ANYTHING HOW THEY ARE NOT GOING TO HAVE A DAMN GUN TO MEASURE THE TEMPERATURE OF THE DEVICE HOW THEY ARE NOT GOING TO FIX THAT THE ROUTER IS OVERHEATING I EASILY THROW 3 EGG AT IT AND IT WILL COOK, DON'T COME AND SAY I HAVE THE ROUTER NEAR THE SUN THE ROUTER 3 THE PERFORMANCE TO OPEN THE PAGE IN A BROWSER I Occupy 2 NAVIGATORS THE OPERA GX AND GOOGLE TAKES A CENTURY AND THEY COME TO TELL ME THAT YOU HAVE A DISADVESTING LAPTOP I HAVE AN ASUS ROG 571 WITH AN I7 AND GTX 965M 20 GB OF RAM AND MY CELL PHONE IS BLACK SHARK 3 AND I HAVE THE 2 CONSOLES THE XBOX SERIES X AND THE PLAYSTATION 5 GOOD ENGINEER FROM DUMAOS, THESE 3 PROBLEMS, I'M GOING TO LEAVE YOU A MORE DETAILED VIDEO. 2023-10-14-17-08-43-722-jy25l.mp4 Screenrecorder-2023-10-14-17-12-36-84.mp4
Administrators Netduma Fraser Posted October 14, 2023 Administrators Posted October 14, 2023 Whats the issue with 5GHz exactly? I don't know if the speed you're receiving or not for that download is good or not as I don't know what your speeds are. On the mobile you've made it load the desktop site which is why it's slow to load, you've gone from the optimized mobile view which is fast to the unoptimized desktop view on a mobile
DARKNESS Posted October 14, 2023 Posted October 14, 2023 @STROXS88 I would use a network analyzer to figure out whether it other channels causing interference in your area and change them if necessary since that can be affecting your wifi speeds. I would also recommend playing over Ethernet to get the most optimal experience it'll cut your latency by half in most cases over wifi. Any router can have over heating issues though I do have to admit there was a design flaw on the Netduma R2 which was the casing were there no ventilation unless it upside down though this isn't the only product in the world that has made mistakes. If it an issue for you do to your local area I'd recommend getting a small fan and installing it below the router in order to prevent over heating crashes. Just giving some advice brother titofuenla 1
STROXS88 Posted October 14, 2023 Author Posted October 14, 2023 THANK YOU HALF A SOLUTION THEN NOW I KNOW WHAT THE SOLUTION IS I BUY THE
STROXS88 Posted October 14, 2023 Author Posted October 14, 2023 YOUR DEVICE WAS MORE EXPENSIVE AND IT GAVE ME A BIGGER PROBLEM AND A PAPERWEIGHT
STROXS88 Posted October 14, 2023 Author Posted October 14, 2023 EL R2 A LA BASURA Y ME COMPRO EL XAIOMI AX 9000
STROXS88 Posted October 14, 2023 Author Posted October 14, 2023 2 hours ago, Netduma Fraser said: On PC it's a lot but it never loads you don't have a good tester so the problem is your testers don't test well there is a way to test a device because they give priority to the damn VPN so that the hackers can do their thing in the little games and They give nothing to the stability of the hardware part that my dear engineer from Dumaos has in his house, they don't know how to do their job, he adds the cherry to this poopy cake on poopy cake on my laptop it is connected with the lan cable so the performance Your interface is very very slow, it is 3.4 century
STROXS88 Posted October 14, 2023 Author Posted October 14, 2023 MY DEAR ENGINEERS OF DUMAOS, FIX THE PROBLEM OF MAKING EXCUSES BECAUSE THE LACK IS ENJOYED
STROXS88 Posted October 14, 2023 Author Posted October 14, 2023 MORE ON IT IT TAKES A LONG TIME TO RELEASE AN UPDATE 3.9 CENTURY AND TO REPAIR A PROBLEM screwING VPN PROBLEM DO NOT COME WITH THINGS
DARKNESS Posted October 15, 2023 Posted October 15, 2023 @STROXS88VPN's are a thing for a reason there used for anonymity there not necessarily used for hacking that just a side effect that comes with it there's bad and good people out there that just how the world works buddy 😂 titofuenla 1
Administrators Netduma Fraser Posted October 15, 2023 Administrators Posted October 15, 2023 You still didn't mention what the issues are, did you want to troubleshoot? How is the VPN given priority? It's a feature that's there, people can use it if they wish to, most don't.
STROXS88 Posted October 15, 2023 Author Posted October 15, 2023 9 hours ago, Netduma Fraser said: I already said it, how are you going to see that your 5ghz router doesn't have power or this stability, no, how are you going to read it as so stupid that you smoked a green one? The 5ghz doesn't have a presentation. device I understand ignorant listen more than 3 years with these problems and now I start to emphasize these problems and they ignore everything
Administrators Netduma Fraser Posted October 15, 2023 Administrators Posted October 15, 2023 You said bad stability and that's it, I don't know what that means unless you describe the specific issues you're seeing that makes you come to that conclusion. If you do that then I can see if the issue is resolvable. If you don't wish to troubleshoot and are just venting that's fine but we won't tolerate being spoken to in that way. titofuenla 1
STROXS88 Posted November 7, 2023 Author Posted November 7, 2023 VID_20231107_011817.mp4 km_20231107_1080p_60f_20231107_014148.mp4
titofuenla Posted November 7, 2023 Posted November 7, 2023 Si esta muy bien que usted explique lo que le ocurre, pero perder los modales no le hara que se solucionen sus problemas. 1º Para el tema del calor ya le dieron una solucion y por lo que veo en el video no a seguido el consejo, yo personalmente no uso ni siquiera un ventilador para que este bien refrigerado, simplemente le coloque debajo un par de dilataciones de oreja de 10mm y simplemente con eso dejo de tener sobre calentamiento, con lo cual es tan facil como buscar algo de 10mm y ponerlo de bajo. Ya sabemos que no deberia de tener que hacer esto y que es un fallo de diseño del R2 pero, una de dos, o haces esto y lo solucionas o lo dejas como esta y sigues teniendo problemas, eso ya es eleccion suya. 2º Sobre el tema del wifi tambien se le aconsejo que utilizara un analizador de wifi para seleccionar la mejor banda y frecuencia. Tambien le digo que en el momento que soluciones el problema del sobre calentamiento tu R2 empezara a trabajar mucho mejor. 3º Esto se lo digo como persona: como le dije, perder lo modales o hablar en tono despectivo no hara que sus problemas se solucionen antes y menos hara que la gente quiera ayudarle, pudes dar gracias que la gente de aqui es agradable y siempre estan dispuestos para ayudar, pero con esos modales poca ayuda encontraras en muchos otros lugares. Un saludo y espero puedas solucinar tus problemas.
STROXS88 Posted November 7, 2023 Author Posted November 7, 2023 POR LOS JAHAS .mp3 INFUMABLE Y SON GENIOS QUE ME HE REIDO CON ESTOS TIPOS
Administrators Netduma Fraser Posted November 7, 2023 Administrators Posted November 7, 2023 ¿Podrías traducir usando Google Translate al inglés, por favor?
STROXS88 Posted November 8, 2023 Author Posted November 8, 2023 Hey, stop being arrogant and repair my router because I haven't asked for anything in 4 years and you're acting illiterate because you don't know and you're the administrator of this forum.
titofuenla Posted November 8, 2023 Posted November 8, 2023 48 minutes ago, STROXS88 said: Hey, stop being arrogant and repair my router because I haven't asked for anything in 4 years and you're acting illiterate because you don't know and you're the administrator of this forum. You still have a shitty attitude and upbringing, you honestly don't deserve any help with your type of behavior. You are simply a hater who comes here to lack respect. As I already told you, good luck with your R2. But I hope you get what you deserve and no one helps you.
Administrators Netduma Fraser Posted November 9, 2023 Administrators Posted November 9, 2023 On 11/8/2023 at 12:33 PM, STROXS88 said: Hey, stop being arrogant and repair my router because I haven't asked for anything in 4 years and you're acting illiterate because you don't know and you're the administrator of this forum. I am illiterate in Spanish, I only speak English, if it's arrogant to ask to translate your Spanish videos/issues into English so I can understand and help you then I don't know what to tell you. I am happy to help once I understand the problem. killianbell and titofuenla 2
