Dimitri Posted April 29, 2023 Posted April 29, 2023 PS5 not showing up in device manager in Duma OS 3.0 in a brand new XR1000. Any ideas?
Krush Posted April 29, 2023 Posted April 29, 2023 8 hours ago, Dimitri said: PS5 not showing up in device manager in Duma OS 3.0 in a brand new XR1000. Any ideas? The easiest way is to connect directly via ethernet to the XR, otherwise use the XR's WiFi SSID!
Krush Posted April 29, 2023 Posted April 29, 2023 3 hours ago, DARKNESS said: Never heard of something called re sync I guess Make an effort , this is a support forum. And not a forum to express your personal frustration!
Administrators Netduma Fraser Posted April 29, 2023 Administrators Posted April 29, 2023 9 hours ago, Dimitri said: PS5 not showing up in device manager in Duma OS 3.0 in a brand new XR1000. Any ideas? Hey, welcome to the forum! How do you have it connected to the router? It's possible that it will have a different name than you're expecting, check the IP on the PS itself then try to match that with the devices shown on the Device Manager and then if necessary you can re-name it.
DARKNESS Posted April 29, 2023 Posted April 29, 2023 6 hours ago, Fuzy said: Make an effort , this is a support forum. And not a forum to express your personal frustration! Says the person who admitted to using cheats lmao but ok buddy can't wait to see this get shadow banned too
Administrators Netduma Fraser Posted April 29, 2023 Administrators Posted April 29, 2023 35 minutes ago, DARKNESS said: Says the person who admitted to using cheats lmao but ok buddy can't wait to see this get shadow banned too Please stop derailing support topics with antagonistic comments
Featured Comment Dimitri Posted April 29, 2023 Author Featured Comment Posted April 29, 2023 I figured it out… my PS5 was connected to LAN and Wifi at same time. That makes it mot show up on DUMA. Disconnected it from Wifi and solved. Thank you all for your input.
Administrators Netduma Fraser Posted April 29, 2023 Administrators Posted April 29, 2023 29 minutes ago, Dimitri said: I figured it out… my PS5 was connected to LAN and Wifi at same time. That makes it mot show up on DUMA. Disconnected it from Wifi and solved. Thank you all for your input. Great to hear that, well done for solving it and thanks for the update!
Posted by Dimitri,
0 reactions
Go to this post
