TODDzillaInLA Posted March 27, 2023 Posted March 27, 2023 if the desk or the cable to the plug moves on my r2 it shuts off and i have to play with it to get it to power back on, how do i go about getting a new one? thank you advanced
DARKNESS Posted March 27, 2023 Posted March 27, 2023 3 hours ago, TODDzillaInLA said: if the desk or the cable to the plug moves on my r2 it shuts off and i have to play with it to get it to power back on, how do i go about getting a new one? thank you advanced Any adapter with specifications such as 100-240V, 50-60Hz; Output: 12V, 1000mA just look for 12V adapter on amazon/whatever site u prefer should find one easily you can also use with with higher ma shouldn't be much of an issue Just make sure that the output is not above 12V if so it has a potential chance to damage the router over time etc
Administrators Netduma Fraser Posted March 28, 2023 Administrators Posted March 28, 2023 As above, that would be the easiest thing to do, here is a picture of the stats just in case: The cable diameter is 2.0mm
TODDzillaInLA Posted March 29, 2023 Author Posted March 29, 2023 On 3/28/2023 at 7:12 AM, Netduma Fraser said: As above, that would be the easiest thing to do, here is a picture of the stats just in case: The cable diameter is 2.0mm the 2 closest ones i think i could find on amazon, let me know. I dont want to order the wrong one https://www.amazon.com/1000mA-Adapter-Security-Surveillance-100-240/dp/B09TSZ67P6/ref=sr_1_1_sspa?crid=3MNFPYRWGYALS&keywords=jzb-1201000b&qid=1680107171&sprefix=jzb-1201000b%2Caps%2C136&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzME43QkxXQjJNVVFDJmVuY3J5cHRlZElkPUEwNDcxMzc1WDdENEhGVkQxWU5SJmVuY3J5cHRlZEFkSWQ9QTA2NjcyOTcxSUZNRU1JRUtENldTJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== or https://www.amazon.com/Adapter-Switching-Charger-Speakers-Appliances/dp/B08C7C4769/ref=sr_1_3?crid=3MNFPYRWGYALS&keywords=jzb-1201000b&qid=1680107259&sprefix=jzb-1201000b%2Caps%2C136&sr=8-3 thank you
Administrators Netduma Fraser Posted March 30, 2023 Administrators Posted March 30, 2023 Not sure about those ones, the diameter for the input plug doesn't seem right but in terms of voltage they're correct
TODDzillaInLA Posted March 31, 2023 Author Posted March 31, 2023 On 3/30/2023 at 7:10 AM, Netduma Fraser said: Not sure about those ones, the diameter for the input plug doesn't seem right but in terms of voltage they're correct can you send me a link to buy one you would recommend on amazon please
Administrators Netduma Fraser Posted March 31, 2023 Administrators Posted March 31, 2023 I'll have a look around but I'd just be searching with the specs I already mentioned, as long as they're correct any adapter will do
TODDzillaInLA Posted March 31, 2023 Author Posted March 31, 2023 have someone pull one out of a r2 box ill pay you for it 🥰
Administrators Netduma Fraser Posted March 31, 2023 Administrators Posted March 31, 2023 35 minutes ago, TODDzillaInLA said: have someone pull one out of a r2 box ill pay you for it 🥰 We could but it'd definitely be more expensive than buying on online, I'll have a look tomorrow and find one for you! TODDzillaInLA 1
DARKNESS Posted April 1, 2023 Posted April 1, 2023 https://www.amazon.com/Adapter-100-240V-Connector-5-5mmx2-1mm-Wireless/dp/B085WK2W6W/ref=sr_1_2?crid=2O2LW2GC4VCOT&keywords=100-240V%2C+50-60Hz%3B+Output%3A+12V%2C+1000mA&qid=1680309810&sprefix=100-240v%2C+50-60hz+output+12v%2C+1000ma%2Caps%2C89&sr=8-2 ALL YOU NEED IS 2.1 DIAMETER SAME THING This one should pretty much work since it universal plug exactly 2 diameter as well https://www.amazon.com/Adapter-Compatible-Motorola-Surfboard-Universal/dp/B07G75PQFP/ref=sr_1_3?crid=SWQS1E32NHGG&keywords=router+power+cord&qid=1680321776&sprefix=router+power+%2Caps%2C93&sr=8-3
Administrators Netduma Fraser Posted April 1, 2023 Administrators Posted April 1, 2023 Having a look online 2.0mm isn't widely available in the US but yes 2.1 should work so as long as you find one with that maximum then you should be good
TODDzillaInLA Posted April 1, 2023 Author Posted April 1, 2023 so im order this one then Amazon.com: TPLTECH 12V Router Power Supply Adapter Replacement for Netgear N300 N600, Motorola/Arris Surfboard WiFi Router, Linksys, Asus, Universal Cable Modem Charger Cord : Electronics thank you guys
Administrators Netduma Fraser Posted April 2, 2023 Administrators Posted April 2, 2023 That looks good to me, especially as it is used to power routers you know it'll be safe to do so for the R2
TODDzillaInLA Posted April 4, 2023 Author Posted April 4, 2023 So my TPLTECH 12V Router Power Supply Adapter Replacement got delivered yesterday and so far so good, thanks guys Netduma Fraser 1
Administrators Netduma Fraser Posted April 4, 2023 Administrators Posted April 4, 2023 Great to hear that, thanks for the update!
