R1 stops working with 2 LAN cables
hey guys
as the title says my R1 stops working the moment i plug a second ethernet LAN cable into the R1 (doesnt matter which port)
the R1 works again as soon as i unplug that cable
with not working i mean that no device can get a connection to the internet or get contact to the R1 interface (but the Wifi still works, just no device can connect to it despite the correct password)
is there something i oversaw in the options that i need to tick?
additional infos:
- ethernet LAN 2 = Xbox One (LAN 1 is the modem ofc)
- potential ethernet LAN 3 = PS4
- Wifi for any other network devices
- r1 firmware 1.03.4 = latest
- i use the following powerline plug that both PS4 and Xbox One are connected to:
$_35.JPG?set_id=880000500F
http://www.amazon.co.uk/Devolo-dLAN-550-duo-wall-pluggable/dp/B00KIHXS7W
If I read that right, port 1 (PoE) of the duma needs to be plugged into your ISP hub and then the other ports should work just fine, so port 2 xbox instead, port 3 ps4 instead.
yes exactly, i should have mentioned that
ill edited my post above to not give false infos
If you've done what Fraser said and plugged into port 1 then ignore this. Otherwise, I had exactly the same problem as you :) Every time I plugged in my PC via ethernet all other devices would lose connection.
Simple fix was to use a different ethernet cable - I looked into it afterwards and I think it was something to do with crossover cables, and auto crossovers in ethernet ports and stuff like that. But changing ethernet fixed it for me :)
thanks a lot for the suggestion crossy, the cable i was using for the PS4 is like 5 years old and has never been really tested my me, found it in the locker and thought it should still be fine
will order a new cable from amazon to verify this
any other suggestions on what could cause this? :)
Shouldn't be, I should think a new cable will fix the issue :)
