not getting speed
Rampage
hello,Everyone
i am getting trouble in speed , i change my plan and my ISP gave me 50mbps dwn/ 50mbps up
but i connect R1 its only give 3-4 mbps dwn/ 13-14 mbps up
i talk my ISP he told me to check on dial up so i check it and the speed is exact what he gave me he told me your router have some problem lol
so i dont know whats going on ,,,,,do you guyz have some settings to try or suggestion post-2048-0-66716100-1437833421.png
Can you make sure you have congestion control set to 100% when doing the tests. Also press 'Reset Distribution' and 'Update Distribution' before doing the test. Finally make sure you are doing the test wired :)
yes crossy
but i will check all settings as u say again and let you know
and also what should i put in algorithm for speed 50dwn/50up??? :)  :)  :)
yes crossy
You shouldn't really need to make any adjustments from default to get => Miscellaneous and also disable IPv6 in Settings >> WAN and Settings >> LAN. You should use the pre-emptive algorithm but if that is still slow try the reactive one :)
