Vlan help
I have the xr500
 How can i setup vlan on this router please help
 I only see the option to  do it from brige mode
 If i try that it puts it into bridge mode and disables the geo filter
 Please help
Thank you but that atriclw is for setting  up  the router in bridgw mode
I dont want to put my xr500 into bridge mode
  As i  cant use geo filter in bridgemode  from my testing so far
I just want to set up   the vl/n on the rouyer or enable vlan on my router
 Im still learning about vlans
Can you explain a bit more as to why you need to use this? Is it because you ISP requires you to use VLAN tagging in order to get an internet connection?
If so, in Settings -> Advanced Settings -> VLAN/Bridge Settings, enable it then tick "By VLAN tag group" then enter the required VLAN ID there.
