Benege Posted October 11, 2022 Posted October 11, 2022 Hey, I have a netduma R2. I have it all set up and it works via Wi-Fi. But when I plug in my Xbox X via Ethernet I get no connection. any ideas? cheers Ben
Netduma Liam Posted October 11, 2022 Posted October 11, 2022 Thanks for posting a new topic for this! I'm not too familiar with the process on an Xbox, but you may need to go to your Network Settings on the Xbox and set it up again through there. I know you need to do this on PlayStation. Try that and let us know if it's working for you!
Benege Posted October 11, 2022 Author Posted October 11, 2022 15 minutes ago, Netduma Liam said: Thanks for posting a new topic for this! I'm not too familiar with the process on an Xbox, but you may need to go to your Network Settings on the Xbox and set it up again through there. I know you need to do this on PlayStation. Try that and let us know if it's working for you! Hey! I tried this and did a network test. It says I can’t connect. Also the device isn’t showing on my duma. It does show when I use Wi-Fi.
Administrators Netduma Fraser Posted October 11, 2022 Administrators Posted October 11, 2022 Are you using automatic network settings on the xbox? Do you have another ethernet cable you can test with in case that one is faulty?
Benege Posted October 11, 2022 Author Posted October 11, 2022 35 minutes ago, Netduma Fraser said: Are you using automatic network settings on the xbox? Do you have another ethernet cable you can test with in case that one is faulty? Yes Automatic. The Ethernet cable is good! Checked it.
Benege Posted October 11, 2022 Author Posted October 11, 2022 Just now, Benege said: Yes Automatic. The Ethernet cable is good! Checked it. It’s says I’m connected via IPv4 and I should read about ipv6
Administrators Netduma Fraser Posted October 11, 2022 Administrators Posted October 11, 2022 Okay so it's all working now then? You don't need IPv6 to have a connection/get a good experience.
