Bernard Posted September 14, 2022 Posted September 14, 2022 Hello, I have in my office a Wifi repeater. The connection is displayed as follow Router => Lan => Repeater (the device) When I use this repeater to connect to the network, the device is sowed as connection to the Lan and not to the repeater. For example if I connect with my iPhone it shows: Router => Lan => Repeater Router => Lan => MyIphone In my opinion it should have shown me the repeater as a node where other devices connect (can be optional to spare space): Router => Lan => Repeater => MyIphone Router => Lan => Repeater => Colleague Android Router => Lan => Repeater => Wireless printer ... Bernard
Bert Posted September 14, 2022 Posted September 14, 2022 The reason for this is that the router does not know if you use a repeater or LAN connection. It detects the interface of the repeater that is why it's shown as LAN. You need a mesh system or a system with controller for that to work properly. Or possibly a netgear repeater with the smart connect option. The router only knows if it's wifi when the device connects through their own interface.
Administrators Netduma Fraser Posted September 15, 2022 Administrators Posted September 15, 2022 Perfect explanation above!
Bernard Posted September 16, 2022 Author Posted September 16, 2022 Thank you Bert for your clear explanation. 🙏 Well sometimes "Perfect explanation" just s..k. 😂😂😂😂😂
