TheJam Posted July 19, 2022 Posted July 19, 2022 Hi, I wasn't sure where to ask this. I have an XR1000 as my main router with an Orbi mesh connected using AP mode. I want to give Guest Network access using the Orbi, however, theĀ 'Allow guests to see each other and access my local network' option is enabled but also greyed out. It seems like the Guest Network still gives access to other devices (seems like that defeats the purpose of a Guest Network?) - is there anything I can do on the XR1000 to stop devices on my AP in a Guest Network from accessing my devices? I read online about having to set up a VLAN but I don't think this is possible on the XR1000. Cheers, Jam
Administrators Netduma Fraser Posted July 19, 2022 Administrators Posted July 19, 2022 No real way to do that other than VLAN, there are VLAN options but you would have to apply it to the Orbi as a whole, you wouldn't be able to specify guest devices. Otherwise you'd have to disable AP mode so the local option becomes changeable
TheJam Posted July 19, 2022 Author Posted July 19, 2022 Cheers Fraser, I didn't think there would be much I could do but appreciate the confirmation on that one.
