Downloading problems
ia there a way i can make it that when i download something everything else that im watching on my pc doesnt start lagging and slowing down until its done
Yes that is exactly what Congestion Control is designed to prevent, set it to 70% download & upload and select Always or Auto-Enable so it only enables when gaming
Are ALL devices connected to the router? What is the model of the modem/router the R2 is connected to?
So everything else is connected to the Verizon router? If so that is why, ALL devices should be connected to the R2 otherwise QoS cannot effectively control your network
4 hours ago, gearsniper550 said:
no i typed it wrong my router is connected to the r2 which has everything connected to the r2
Can you provide a screenshot of your QoS settings please?
Are the speeds configured in Congestion Control accurate for your network? You get about 20Mbps up and down?
If so, reduce the sliders down to about 70% each.
Make sure DumaOS classified games is enabled in Traffic Prioritisation and that should resolve the issue for you.
