Geofilter help
Shayrza
Goodmorning, i'm an EU player i usually put my Geofilter on Mid Usa with wide km to play over there with my local friends.
it happen ALOT that after i SETUP the Geo Filter, i queue-->110+ping ( that's ok i know that's Duma is working), but after one games, when i RE-queue i have 20-25MS ping so i returned back on my Location, and i have to
-quit the game
-turn off geofilter
-turn on geofilter
-run the game again
i'm doing somethings wrong? or can i do somethings to avoid to keep redoing all this all the time?
it's not happening for every game but very often
Welcome to the forum!
That's odd, do you actually get into a game on 20-25ms ping or does it just say that you're looking for a game on that kind of ping?
Are any icons showing in Geo-filter when it starts looking for lower ping matches?
i have 9 home ping and on EU 20 ping.
when i geofilter in america central i start with 110 ping more or less and (i assume) so i know it's working and i play normally
but after 1 or few games when i requeue i have 20 ping again and i have to shut down the game , turn off on the geofilter and reopenit.
shoud i try to keep in queue after when i see 20 ping?
thanks
Are you allowing anything in the EU or playing with a friend who is in the EU also? Possibly it's detecting through them where you are and will try to put you on a closer server, if you give it time it should eventually force US still
