Harley Posted May 8, 2022 Posted May 8, 2022 I was running tests from my ISP and decided to check the performance of Congestion Control and discovered that while the download congestion control seems to be working just fine, the upload is not working at all. 21.5mbps is the maximum upload I can achieve and its supposed to be limited to 13mbps yet it's still achieving 21.5. Here are the screenshots....
Administrators Netduma Fraser Posted May 8, 2022 Administrators Posted May 8, 2022 Are you using IPv6, VLAN, PPPoE or DHCP Identifiers by any chance? If so that is likely why and we'll get that sorted
Harley Posted May 8, 2022 Author Posted May 8, 2022 I am not using IPV6. Not sure what the rest means! Would this benefit going back to the previous version of firmware? Oh, I think the answer to the pppoe is yes.
Administrators Netduma Fraser Posted May 8, 2022 Administrators Posted May 8, 2022 No that's unlikely, it's due to PPPoE I believe, can you have the ISP modem/router handle PPPoE instead? If so that would resolve it.
Harley Posted May 8, 2022 Author Posted May 8, 2022 22 minutes ago, Netduma Fraser said: No that's unlikely, it's due to PPPoE I believe, can you have the ISP modem/router handle PPPoE instead? If so that would resolve it. I am afraid not. The modem as such has no configuration at all.
Administrators Netduma Fraser Posted May 8, 2022 Administrators Posted May 8, 2022 Do you have any spare routers you could use to do that? Otherwise unfortunately it'll have to wait for a firmware update to fix it
Harley Posted May 8, 2022 Author Posted May 8, 2022 36 minutes ago, Netduma Fraser said: Do you have any spare routers you could use to do that? Otherwise unfortunately it'll have to wait for a firmware update to fix it I will probably wait. I suppose that will be about six months or so ( random guess, lol ). Why is it even a problem? I would have thought that it was a common issue. The modem, incidentally is the new Openreach ( nokia ) ONT and I don't think it has any configuration.
Administrators Netduma Fraser Posted May 8, 2022 Administrators Posted May 8, 2022 I'm not a dev so I couldn't say why it's not working exactly, I suspect it will be resolved in the next firmware which shouldn't be too far away now, you can keep up to date by following this page: http://support.netduma.com/en/support/solutions/articles/16000132677-dumaos-firmware-progress
Harley Posted May 8, 2022 Author Posted May 8, 2022 I just checked and the ONT doesn't have any configuration so there is no hope of setting something up in the modem. Shame, but there you go.
