ownal0t Posted March 1, 2022 Posted March 1, 2022 This is the First time im dealing with this at such a high rate. but ever since Ranked came out, i been getting GUNNED but not in the , wow hes just better type of way (which i would be okay with), but in the im mag dumping you and some how get 2 shotted type of way which makes me lose full. what settings are yall touching to get decent hit detection.... things i already did... are in the pic, i also DMZ'd the PC and i turned off UPnP Thanks in advance
ownal0t Posted March 2, 2022 Author Posted March 2, 2022 58 minutes ago, DumaGuy2021 said: For one, turn upnp back on only asap! i turned it back on , havent ran a game yet tho.
Infoseye Posted March 2, 2022 Posted March 2, 2022 Everyone at some point has gotten a fair share of shot first and die first, if you get killed by two shoots 2 possible cause from my personal experience. One you are bad server/host or further from it or secondly your setup connection is bad(Internet ,ping, buffer float etc) its worth taking time out to-do a test on your internet line. I suggest 2 things, which I have done that solved this issue for me. 1. Inspect your ethernet cable, swap it out for a new one it wouldn't hurt using new cable for your pc, cable from your internet box to netduma router. For me this fixed the annoying LAN disconnected notification I get an random on PS5. 2. On Netduma put your home location middle of the ocean and set the radius to the lowest 111 set your ping assist to 30, once you made changes reboot netduma and the PC. Launch the game play couple of games lets us know if it helped.
Max2110 Posted March 2, 2022 Posted March 2, 2022 20 minutes ago, Seye said: Everyone at some point has gotten a fair share of shot first and die first, if you get killed by two shoots 2 possible cause from my personal experience. One you are bad server/host or further from it or secondly your setup connection is bad(Internet ,ping, buffer float etc) its worth taking time out to-do a test on your internet line. I suggest 2 things, which I have done that solved this issue for me. 1. Inspect your ethernet cable, swap it out for a new one it wouldn't hurt using new cable for your pc, cable from your internet box to netduma router. For me this fixed the annoying LAN disconnected notification I get an random on PS5. 2. On Netduma put your home location middle of the ocean and set the radius to the lowest 111 set your ping assist to 30, once you made changes reboot netduma and the PC. Launch the game play couple of games lets us know if it helped. Thanks for the tips, I too will give it a try. May I ask which country u are from seye?
Infoseye Posted March 2, 2022 Posted March 2, 2022 31 minutes ago, Max2110 said: Thanks for the tips, I too will give it a try. May I ask which country u are from seye? From Nigeria why? Just curious why you asked I noticed with the steps I get connected to all decent servers across the globe, am not limited my geographical location. I noticed I have been getting newbie lobbies to not everytime thou.
Max2110 Posted March 2, 2022 Posted March 2, 2022 4 hours ago, Seye said: From Nigeria why? Just curious why you asked I noticed with the steps I get connected to all decent servers across the globe, am not limited my geographical location. I noticed I have been getting newbie lobbies to not everytime thou. Because I'm from South Africa and you probably connect to my server a lot
Infoseye Posted March 2, 2022 Posted March 2, 2022 44 minutes ago, Max2110 said: Because I'm from South Africa and you probably connect to my server a lot Its possible you can host me some time, Europe/UK lobbies are sweaty as hell most times.
Max2110 Posted March 2, 2022 Posted March 2, 2022 1 hour ago, Seye said: Its possible you can host me some time, Europe/UK lobbies are sweaty as hell most times. Sure invite Aimbot_no1 on psn
