CRarsenxL Posted March 1, 2022 Posted March 1, 2022 Whenever I run an HTML 5 speed test , I get 700/700 w the R2. W my XR1000 I get 800/900 w my RAX120 I get 940/940 I’ve tested multiple times and values stay low. QoS disabled ofc. Reflashed FW and FAC reset etc etc. Is it the .394 FW causing this issue?
Netduma Liam Posted March 1, 2022 Posted March 1, 2022 16 hours ago, CRarsenxL said: Whenever I run an HTML 5 speed test , I get 700/700 w the R2. W my XR1000 I get 800/900 w my RAX120 I get 940/940 I’ve tested multiple times and values stay low. QoS disabled ofc. Reflashed FW and FAC reset etc etc. Is it the .394 FW causing this issue? Which speed test are you using exactly? Are you seeing the same results across all speedtests or do they differ? What speeds does Connection Benchmark report?
CRarsenxL Posted March 2, 2022 Author Posted March 2, 2022 10 hours ago, Netduma Liam said: Which speed test are you using exactly? Are you seeing the same results across all speedtests or do they differ? What speeds does Connection Benchmark report? All speed tests
Netduma Liam Posted March 2, 2022 Posted March 2, 2022 What speeds does Connection Benchmark report? Were you getting this issue on previous firmwares or have you only noticed it on the latest?
