PC on lan connection disconnects
There is no specific reason a singular device would suffer disconnections and not others. Did you try it direct to the modem and see if you had the same issues?
Yep! I did that same thing and it’s still doing it. At this point I am getting in contact with AT&T and see if they can send me a new modem. I have a feeling it’s the modem that i currently have. Hopefully that will fix the problem.
Ok so I tested everything, and it's definitely not my network card, I also bought a wifi adapter to see if it worked without disconnecting and I did encounter the same issue with disconnecting me while playing video games (WoW & CoD). At this point I'm no even sure what to do, Would doing a factory reset on the xr500 possibly reset and fix this issue with the disconnecting? I'm also going to see if AT&T will send me a new modem/router, maybe the one I have is crap.
Would maybe even having IKEv2 vpn protocol enabled possibly cause these disconnects to occur? Or maybe having high latency while gaming possibly disconnect me?
A factory reset is always a good idea if all other troubleshooting steps have failed so do give it a try. Using a VPN adds another aspect to your connection, if a VPN server goes down for whatever reason you would be disconnected, if your ping exceeds what the game deems are a reasonable ping for a game then you could be kicked from the game if it increases during the match - are you using a VPN on the PC then? If so I would suggest disabling that first before you do a factory reset and see if it makes a difference.
  • 1 month later...
Went ahead a bought a new CAT8 cable and now is working perfectly fine now with no disconnects. Thanks for the help!
Excellent, thanks for letting us know! Give us a shout if you need anything else!
