So many problems
mukey
Okay so my discord does not work on my phone anymore.
Also when I open normal links to websites, or even try to go to this website (forum.netduma.com) I get an error saying can’t connect, but then it will connect after about 5-10 refreshes sometimes, most times it just does not connect.
I’ve never had either of these problems till today. 2C298D32-C443-41A0-85ED-92FBB3D6A3DD.thumb.png.d984279842d452b90377685a793cb071.png
Update the router to the last version, once you updated it reset it and fresh start, you should be ready to go
Okay so if you haven't experienced this issue before was there anything you changed on the router prior to this occurring? The above is a good suggestion if you haven't done so already
