jin1234 Posted December 14, 2021 Posted December 14, 2021 I’ve been using the nighthawk router in bridged mode connected to my Comcast modem. It was working well for a while but in the past couple months the quality has been deteriorating and it’s been causing connection issues along with much much slower speeds. Ive tried disabling QoS, opening ports, scanning channels being used and assigning open ones, I’ve had to do countless reboots and factory resets. I don’t know what else to do and I hope you guys have something I can try that will solve this because I don’t know what can solve.
Netduma Liam Posted December 14, 2021 Posted December 14, 2021 Welcome to the forum! What kind of network issues are you having? Can you describe these a little further? Where are you measuring the speeds exactly? Are you using a third-party speed test or are you using the Connection Benchmark?
