Netduma R1 internet keep dropping HELP
FeelTheBubbles
What firmware are you on currently? Is it WiFi or wired devices or both? How often does it occur? Does there seem to be any pattern as to when it happens e.g. during high internet usage?
Am on the 3.0 Version, it’s wired it’s been happening for a week now. When  a turn on the pc 15 minutes later am disconnected then it happens 4-5 times for 10 minutes a hour goes by does it again
3.0.207, correct?
Are you able to get to the DumaOS interface in your web browser when the disconnection occurs?
Is this occurring on all devices or is it just the PC? If you go into the Network Settings of the R1 and reserve an IP for the PC, does it continue to disconnect?
5 hours ago, Netduma Liam said:
3.0.207, correct?
And it’s just me pc and me iPhone. What’s connected both
Go to Settings, set DHCP start to .10, adjust the lease hours to 168, give the PC and iPhone a reserved IP, 192.168.88.5 and 192.168.88.6 respectively, apply then reboot the PC and phone. See if it is more stable after that please.
Spoiler
how do a give the pc and ip sorry for this nvm a done it it wont let me put the 5 on the end
That's all correct, make sure you apply/save then reboot the router from the interface, wait 2 minutes before connecting and see if it is more stable.
