Help me pls
Qolse_20000
When I put on the hot map it shows me that my lowest ping is in Los Angeles CA but there it marks 312 pings, and it sends me to Europe with 15 pings, how can I fix that so that it respects my ping16388409786644361669965607141582.thumb.jpg.5b68c74c17dfd398c2e7b87a8ca9e811.jpg
I am from Mexico and my servers are good but it does not connect where I have the lowest latency, is there any way that my server is well established, what could I do
I'm exactly from CDMX and the server I'm trying to connect to is Los Angeles in Fortnite
Is there any way to update that server or why is it not looking for me under ping, only connect on San Francisco
Servers are not always available and they may come and go depending on the game population at the time. Turn Ping Assist to 0 then place your radius just covering Los Angeles and it should work better - make sure to do this before you turn on the game.
