Max Posted December 4, 2021 Posted December 4, 2021 Hi guys I need some help i change speed of my broadband to 500/70 and I can’t get the full speed via WiFi I’m using ookla speed test and on r2 I’m getting results in about 200 but when I change router to Bt the speed test showing full 500 is it any settings in r2 to be changed to get full speed? thanks max
Administrators Netduma Fraser Posted December 4, 2021 Administrators Posted December 4, 2021 I'd suggest disabling Mirror Mode, then giving 2.4/5GHz different names, apply, reboot from the interface, wait 2 minutes then access. Use a WiFi analyzer to find the least congested channels in your area for 2.4 and 5GHz then change to that. Also experiment with the widths and see what gives you the higher speeds on 5GHz.
Administrators Netduma Fraser Posted December 4, 2021 Administrators Posted December 4, 2021 You can download one on the Microsoft Store for Windows, called WiFi Analyzer, it's free
Max Posted December 4, 2021 Author Posted December 4, 2021 265 is the best what I can get with different channels and widths on Bt router it’s 500 all the time any other suggestions? thanks
Max Posted December 4, 2021 Author Posted December 4, 2021 And also I can’t get 500 doing the test on r2 this one is the highest one maybe I have wrong settings on r2?
Max Posted December 4, 2021 Author Posted December 4, 2021 With traffic prioritarization I have only 16 mbs upload on ps5 🤷♂️ any advice will be great thanks for all help
Administrators Netduma Fraser Posted December 4, 2021 Administrators Posted December 4, 2021 The hub may have higher WiFi specs than the R2 so the 265 is likely the max you'll be able to achieve but just in case make the antennae look like this _ | | _ and ensure there are no electrical or wireless devices (e.g. headphones, remotes etc) within 3 feet of the router, if possible ensure it's not on a metal shelf. We're still improving results on Benchmark though they're pretty good on the R2, if you use a normal speed test site you should get the correct speeds via ethernet so you won't be limited. Console speed tests can be inaccurate and you won't need much upload at all for gaming so you will be getting what is needed
