Xaosit Posted November 3, 2021 Posted November 3, 2021 When trying to redirect ports, it throws an error. I tried to overload the router, nothing has changed. I don’t understand how to fix it. Month 2 maybe did nothing
Netduma Liam Posted November 3, 2021 Posted November 3, 2021 Welcome to the forum! Where are you seeing this error? In the Network Settings or in QoS when trying to setup a manual rule? It's generally caused because the ports in two of your rules overlap.
Xaosit Posted November 3, 2021 Author Posted November 3, 2021 Network setting - port forwarding When you try to enter the desired port, an error pops up. Previously, this was not the case, I did not prescribe for a long time, and then there is an error
Administrators Netduma Fraser Posted November 3, 2021 Administrators Posted November 3, 2021 Can you show us what port rules you have successfully added and then the one you're trying to add please?
Xaosit Posted November 3, 2021 Author Posted November 3, 2021 I wrote in about six months ago, probably for one game, but now for another I tried and failed
Xaosit Posted November 3, 2021 Author Posted November 3, 2021 Perhaps the router does not like this port, is this possible?
Administrators Netduma Fraser Posted November 3, 2021 Administrators Posted November 3, 2021 You've got overlapping ports there that's why you're getting the error - the second rule and second to last rule. Delete both and combine them 27000-27050 and then it will work
Xaosit Posted November 3, 2021 Author Posted November 3, 2021 Thanks for the help. Corrected. I guessed that somewhere I could make a mistake.
