todd999 Posted October 27, 2021 Posted October 27, 2021 I have 1GM speed fiber and when I connect my computer directly to the modem/router via ethernet or wifi I get a speed of 800+ . (router is 3 ft from computer used for testing) When I connect via the Netduma R2 which is plugged into the modem from the cable company the speed is much lower like 90 down 70 up. Do I have it configured wrong?
Administrators Netduma Fraser Posted October 27, 2021 Administrators Posted October 27, 2021 It may be the cable that is limiting you, can you go to the Device Manager, click the icon then go to table view and provide a screenshot of what you see please?
Administrators Netduma Fraser Posted October 27, 2021 Administrators Posted October 27, 2021 Yep so the cable connecting the router to the modem is limited to 100Mbits, you'll need to switch it to a cable capable of 1000Mbits and then you should get higher speeds
todd999 Posted October 27, 2021 Author Posted October 27, 2021 What do you recomend Cat 7? I was using a Cat 6 cable
ap1314227 Posted October 28, 2021 Posted October 28, 2021 So I'm having similar issues, much faster speeds from my provider, but much slower speeds and pings are all over the place, both wireless and wired.
Netduma Liam Posted October 28, 2021 Posted October 28, 2021 10 hours ago, todd999 said: What do you recomend Cat 7? I was using a Cat 6 cable Cat 6 should be fine, but do try a different cable anyway as it sounds like there could be an issue with the one you're using. 8 hours ago, ap1314227 said: So I'm having similar issues, much faster speeds from my provider, but much slower speeds and pings are all over the place, both wireless and wired. Welcome to the forum! Could you please start a new topic for your issue?
todd999 Posted October 28, 2021 Author Posted October 28, 2021 could the speed slow down be due to the router not in bridge mode? see below new Cat 6 cable but same speed issue
Administrators Netduma Fraser Posted October 28, 2021 Administrators Posted October 28, 2021 If there are other devices connected to the ISP router then yes that could be it. Okay so the router should receive high speeds now - are you testing over WiFi as there is no wired device to the R2 currently
